How to add 3rd region to chtMultiRegionFoam
Old   March 29, 2010, 12:19
Default How to add 3rd region to chtMultiRegionFoam
Ben K
benk is on a distinguished road
Has anybody tried to extend chtMultiRegionFoam to 3 regions? For example, in the current chtMultiRegionFoam example, there are 2 regions: a fluidRegion and a solidRegion. I'm trying to make a third region (let's just call it fluidRegion2).
I don't know how to modify the coupleManager files though. Specifically this part in chtMultiRegionFoam/coupleManager/coupleManager.C:
bool Foam::coupleManager::regionOwner() const
    const fvMesh& nbrRegion = neighbourRegion();
    const regionProperties& props =
        localRegion_.objectRegistry::parent().lookupObject<regionProperties>
            "regionProperties"
    label myIndex = findIndex(props.fluidRegionNames(), localRegion_.name());
    if (myIndex == -1)
        label i = findIndex(props.solidRegionNames(), localRegion_.name());
        if (i == -1)
            FatalErrorIn("coupleManager::regionOwner() const")
                << "Cannot find region " << localRegion_.name()
                << " neither in fluids " << props.fluidRegionNames()
                << " nor in solids " << props.solidRegionNames()
                << exit(FatalError);
        myIndex = props.fluidRegionNames().size() + i;
    label nbrIndex = findIndex(props.fluidRegionNames(), nbrRegion.name());
    if (nbrIndex == -1)
        label i = findIndex(props.solidRegionNames(), nbrRegion.name());
        if (i == -1)
                << "Cannot find region " << nbrRegion.name()
        nbrIndex = props.fluidRegionNames().size() + i;
    return myIndex < nbrIndex;
At the moment my C++/OpenFOAM knowledge isn't good enough to figure out what's going on here, but I'm sure that this has to be modified if a third region is to be implemented. Has anybody done this or help me out?
benk is offline   Reply With Quote
Old   April 3, 2010, 17:22
Eugen
jonya is on a distinguished road
For create a new region you don't need to modify coupleManager. Just create in your case new folder with 3rd region mesh like in tutorial. In regionPriperties you should put type of your region.
jonya is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Other] Importing regions from 3rd party meshing programms suitup OpenFOAM Meshing & Mesh Conversion 1 November 10, 2009 09:40
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
