Spatial averaging
Like Tree2Likes
  • 2 Post By deji
Old   April 2, 2010, 16:10
Default Spatial averaging
n/a
deji is on a distinguished road
Good afternoon everyone. I am hoping to do a turbulence simulation over the weekend and would like to spatially average the flow field in the homogeneous flow direction. This will done after I have time-averaged the solution. So does anyone know if I can use a tool in OpenFOAM to do spatial averaging? Thanks.
Deji
deji is offline   Reply With Quote
Old   October 12, 2012, 16:43
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hallo Deji,
Did you find the answer to you question?
regards,
Awais
owayz is offline   Reply With Quote
Old   October 13, 2012, 00:22
n/a
I do have a code that helps me average in a given direction. Why do you ask?
Old   October 13, 2012, 10:12
Awais Ali
Do you right the average as a field?
I am doing an LES of flow over a circular cylinder and I need to average UMean and pMean over span-wise direction. That's is why I am asking this question.
Regards,
Awais
Old   October 13, 2012, 22:34
n/a
I am not sure if I comprehend your question, but the spatial averaging is performed by prescribing which field will be averaged. The code basically takes the field and the direction to average in and collapses the domain into one plane. I am not certain if it will work for a circular cylinder; my geometry is a flat plate. What kind of mesh are you utilizing for your simulation?
Cheers,
Deji
Old   October 13, 2012, 22:54
Awais Ali
Well you perfectly understood what I want to do.
My simulation is of flow over a circular cylinder. I want to average in spanwise direction of time averaged quantities.
If you have the code and you can share, that would be of great help.
Regards,
Awais
Old   October 13, 2012, 22:56
n/a
Okay. I can post the code and some notes to help as well.
Old   October 16, 2012, 21:10
n/a
My apologies for not posting the code in a timely manner, it has been a rough week. I hope to post the code tomorrow.
owayz and gregjunqua like this.
Old   October 19, 2012, 20:40
Awais Ali
Thanks in Advance Deji.
I will wait for your code. As I need it.
Regards,
Awais
Old   October 24, 2012, 20:58
n/a
The code is attached. My apologies for just getting the code to you; I have being fairly busy.
Old   October 24, 2012, 21:22
Awais Ali
Late is not a problem.
Thanks for sharing the code.
Regards,
Awais
Old   January 29, 2013, 08:18
Default Which version
  #12
Martin Söder
Soder is on a distinguished road
Which version of openFoam does it work for?
I tried installing it with 2.0
And got following error:
lnInclude/cuttingPlane.H:122:14: note: candidate is: void Foam::cuttingPlane::reCut(const Foam:rimitiveMesh&, bool, const Foam::labelUList&)
sampledSurface/sampledAveragePlane/sampledAveragePlane.C:212:49: error: no matching function for call to 'Foam::sampledAveragePlane::reCut(const Foam:olyMesh&, const Foam::cellZone&)'
make: *** [Make/linux64Gcc45DPOpt/sampledAveragePlane.o] Error 1
Best regards
Martin
Soder is offline   Reply With Quote
Old   May 7, 2014, 21:15
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
I could not unzip the file. It gives me some error, says file is empty. Any one can help
mmmn036 is offline   Reply With Quote
Old   January 25, 2016, 00:23
Default Download, direct unzip and open with notepad+++++++++bbye
  #14
Rupesh Verma
roopesh99 is on a distinguished road
Download, direct unzip by winrar and open with notepad+++++++++bbye
roopesh99 is offline   Reply With Quote
different between the various averaging huwei CFX 3 February 22, 2015 13:09
When to use mass flow averaging cspectre CFX 2 December 6, 2009 05:30
Averaging field over a spatial direction fs82 OpenFOAM 10 August 12, 2009 10:44
Averaging LES iko FLUENT 3 July 3, 2008 05:55
Laplacian-weighted averaging Ruben Main CFD Forum 0 August 21, 2005 20:46
