Lagrangian Particles
Old   October 14, 2010, 13:01
spej is on a distinguished road
This if-case is not implement in the HardballParticle.C. I believe this missing case is the reason for the endless loop. But I can be wrong with my assumption. Do you solve the problem with the break up? Maybe you can send me your syntax?
regards
spej is offline   Reply With Quote
Old   October 18, 2010, 08:58
You can find the if (onBoundary() && td.keepParticle) case in the while(data.keepParticle && (tEnd<SMALL) && (!data.switchProcessor)) direction of the soliParticle.C file. I believe the missing term is the reason for the endless loop in the while statement.
edit: My assumption was wrong. The last simulation with the extra if-case breaks up as the simulations did before.
@RoRo: How do you solved the break up problem?
Mapping Lagrangian particles gschaider OpenFOAM Bugs 7 December 20, 2023 08:45
Lagrangian material particles bramv101 STAR-CCM+ 5 October 23, 2017 05:27
Sampling tool for Lagrangian particles sankarv OpenFOAM 1 July 1, 2010 11:34
Creating Lagrangian particles for postprocessing hjasak OpenFOAM Post-Processing 6 July 2, 2008 10:59
lagrangian particles allan Siemens 1 August 18, 2004 05:01
