mass defect with compressibleInterFoam
Old   October 22, 2009, 06:31
Exclamation mass defect with compressibleInterFoam
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I have a problem using compressibleInterFoam. I set up a small test case for myself to investigate different boundary conditions, therefore the test case was very small. As I noticed, the water in my test case disappears over time. I then started investigating the tutorial case depthCharge2D, since this was the case I started out from using compressibleInterFoam. I modified the case that it does not have the over pressure bubble, but only water inside the closed volume. All the walls are solid, but still, after some time the water disappears. The setFieldDict and the controlDict (set to endtime to 20 seconds) was modified.
The modified case can be downloaded here ->
http://xi.cheleb.net/files/OpenFoam/ (497kB) It is quite peculiar how the water disappears. It tried different values for gravity and this seems to affect the velocity with which the water disappears.
Maybe somebody can help
~roman
romant is offline   Reply With Quote
Old   April 19, 2010, 08:33
romant's Avatar
Roman Thiele
solved the problem by using buoyantPressure as BC
~roman
compressibleinterfoam, mass defect
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 02:42
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
