if-loop, volScalarField comparison
Like Tree3Likes
  • 1 Post By volker
  • 1 Post By alberto
  • 1 Post By alberto
Old   April 19, 2010, 11:29
Default if-loop, volScalarField comparison
Volker Tritschler
volker is on a distinguished road
I have a problem with a task, which seemed to be straight-forward to solve at first.
I need to program an if-loop in order to compare one volScalarField (P1) to another one (P2), and for each grid point, where P1 >= P2, a certain value (d) has to be written to another volScalarField (N) at exactly the same grid point.
I wrote something like:
(a, b, c, d are placeholder for arbitrary volScalarFields)
volScalarField P1 = a;
volScalarField P2 = b;
volScalarField N = c;
    if (P1 >= P2)
    N = d;
    else
    N = -d;
The problem is that the code in the actual version does not compare the values for every single grid point and hence does not write the value (d) to (N) for all the grid points where the logical expression is true (P1 >= P2).
It's more that it just compares just one (the first?!) point of P1 with P2.
Right now, I don't have any idea how to get rid of that problem, though it seems to be a very silly one.
Thanks for any idea.
greets, volker
neeraj likes this.
volker is offline   Reply With Quote
Old   April 22, 2010, 00:30
Alberto Passalacqua
you have to loop over your cells to compare information in each point:
forAll(P1, cellI)
  if (P1[cellI] > P2[cellI])
    N[cellI] = ...
  else
Best,
neeraj likes this.
Alberto Passalacqua
Old   April 22, 2010, 03:42
Volker Tritschler
hi alberto,
so many thanks for your help!!! It worked great.
I wasn't aware of that class 'cell'.
Do you know if there is a way to loop over the boundary patches as well?
best
volker
Old   April 22, 2010, 10:11
Alberto Passalacqua
Originally Posted by volker View Post
hi alberto,
It's not a class, it's just an index created locally by the forAll loop
Yes, let's assume you want to loop over the boundaries of a field p:
forAll(p.boundaryField(), patchi)
        // Check if it's zeroGradient (optional, depending on your case)
        if (isA<zeroGradientFvPatchScalarField>(p.boundaryField()[patchi]))
            otherFieldA.boundaryField()[patchi] = 0.0;
            otherFieldB.boundaryField()[patchi] = 0.0;
Best,
neeraj likes this.
Alberto Passalacqua
Old   April 23, 2010, 13:02
Volker Tritschler
perfect, big thanks to you!
Old   April 23, 2010, 14:18
Alberto Passalacqua
You're welcome
Alberto Passalacqua
Old   February 27, 2020, 15:13
tooran
tooran is on a distinguished road
I am tyring to change a viscoisty model. I need to campare strain rate with a constant parameter (gama)
if strainrate is greater than the gama then do....
so I write :
Foam::viscosityModels::MyHerschelBulkley::calcNu() const
dimensionedScalar tone("tone", dimTime, 1.0);
dimensionedScalar rtone("rtone", dimless/dimTime, 1.0);
tmp<volScalarField> sr(strainRate());
forAll(calcNu.internalField(), cellI)
if (sr[cellI]< gama_.value())
It shows me the error:
error : calcNu’ does not have class type forAll(calcNu.internalField(), cellI)
could you please help me?
MyHerschelBulkley.C
MyHerschelBulkley.H
tooran is offline   Reply With Quote
Old   March 6, 2020, 20:03
tooran
Can any one help me?
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
ForAll loop and vector comparison juho OpenFOAM Running, Solving & CFD 4 June 17, 2011 09:51
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
for loop inside a cell_loop? MHDWill FLUENT 0 September 26, 2007 21:24
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
