Is it possible that make sampling plane not triangulated |
May 7, 2010, 04:11 |
Jiang
Rep Power: 16 |
Dear All:
I am using sampling plane to sample an internal plane. But the sampled plane is always triangulated. Because my mesh is all cubic, so the cutting face is always beaufiful, doesn't need to be triangulated. how could I modify the code to make the triangulated off ? Thanks. |
May 7, 2010, 15:36 |
Cedric Van Holsbeke
Rep Power: 16 |
Set triangulate to false in the sampling functionObject
surfaces ( newPlane { type plane; basepoint (0 0 0); // coordinates of basepoint of the plane normalVector (0 1 0); // coordinates of the normal vector of the plane triangulate false; } ) |
May 26, 2010, 23:25 |
Jiang
Rep Power: 16 |
Dear Cedric Van Holsbeke,
It seems that "type plane" is always triangulated, we can't select. for "type patch", we can select triangulated or not. So I think we should modify the code ,not controlDict. Thanks for your reply. |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
