Dimension problem rhoPisoFoam
Old   May 27, 2010, 08:26
Default Dimension problem rhoPisoFoam
FabOr is on a distinguished road
Hi all,
i am new to OF and have a dimension problem when i want to solve a turbulent, compressible case.
So what dimensions should alphaSgs, muSgs, nuSgs, and nuTilda have?
I would be also pleased if anyone can tell me anything about these variables, for example their expression in equations like navier-stokes,...
thanks!
FabOr is offline   Reply With Quote
Old   May 28, 2010, 07:36
i solved this problem by editing the p dimension to [1 -1 -2 0 0 0 0]
I´ve forgot that i´ve copied the files out of an incompressible case
Old   May 28, 2010, 07:40
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
Yes. From what I have experienced so far, the best practice scientifically and in terms of programming is to write down all equations your solver uses and see if the units are all the same.
thekay is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
