outlet problem
Old   May 28, 2010, 08:19
Default outlet problem
FabOr is on a distinguished road
i try to programm a vacuum-champer pump out, so there is only one outlet with the BC pressure zeroGradient and velocity fixedValue, because the pump can pump out a defined volume/sec. On all other BC (walls), p and U have both zeroGradient.
but when i run the case with rhoPisoFoam, the pressure icreases instead of decrease. i donīt know why this happen.
Can anyone help me?
FabOr is offline   Reply With Quote
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 11:49
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
CCM+ Outlet BC for Ship Resistance Steve Siemens 3 May 8, 2008 19:12
Problem with the pressure outlet sami FLUENT 6 July 11, 2007 17:33
