June 9, 2010, 08:40 |
Sample utility not working properly
Dear Foamers
I am having problems using the sample utility in either OpenFOAM 1.6 and OpenFOAM 1.5 Dev. To better understand what is going on, I went to the description in the internet of solidDisplacementFoam, to check out in particular the variable definition, to see if there was anything in the variable definition that was hindering the operation of the sample utility. After some tests, I found out the following. - Only for variables defined for the mesh it was possible to sample. For example, for D is possible as it is defined as volVectorField D 00003 ( 00004 IOobject 00005 ( 00006 "D", 00007 runTime.timeName(), 00008 mesh, 00009 IOobject::MUST_READ, 00010 IOobject::AUTO_WRITE 00011 ), 00012 mesh 00013 ); but sigmaD no, being D defined as 00041 ( 00042 IOobject 00043 ( 00044 "sigmaD", 00045 runTime.timeName(), 00046 mesh, 00047 IOobject::NO_READ, 00048 IOobject::NO_WRITE 00049 ), 00050 mu*twoSymm(fvc::grad(D)) + lambda*(I*tr(fvc::grad(D))) 00051 ); Please note the differences, sigmaD involves a calculated field, D not. Also, I cannot extract single components, but, as I got all the components separately, there is not much of a problem, only more numbers.... But, to know how to extract single components will be nice indeed... How I can sample sigmaD? Is the sample utility not suitable for this? Should I use probes instead? Why there is an example of the usage of samples that does not work at all? I do not believe this is problem of the system I am using, Ubuntu 8.10. If anyone have some ideas, please answer me and help me out. Regards, António Martins |
June 9, 2010, 09:00 |
Anton Kidess
Rep Power: 29 |
I think the important difference here is that D is AUTO_WRITE, while sigmaD is NO_WRITE. If you write out sigmaD to disk, you should be able to sample it.
June 9, 2010, 10:45 |
Tried but did not work
Akidess,
Changed the definition of sigmaD to AUTO_WRITE, and I got segmentation fault after applying the sample utility. But, if I do the same for the variable divSigmaExp, a vectorField calculated, I got results. SigmaD is a symmetric tensor field, so it seems there is a problem in the software. It may be: - I am using the wrong comand to write the components. - Sample does not work for tensors. Can you help me on this. Regards, António Martins |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 18:04 |
ParaView or Sample Utility | ternik | OpenFOAM | 0 | April 5, 2010 15:15 |
Understanding the coordinates of sample utility | vishwa | OpenFOAM Post-Processing | 4 | March 25, 2010 12:51 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 12:12 |
Sample utility not working in OpenFoam1.5 dev | titio | OpenFOAM Post-Processing | 1 | December 10, 2009 02:38 |
