June 17, 2010, 07:45 |
Valve open/closed
Rep Power: 15 |
Hi all,
i try to simulate a flow in a pipe. in the middle of the pipe, i try to implement a valve which should open when the pressure difference is high enough otherwise it should be closed. so, are there any examples in the tutorials where valves are used? how can i implement a valve? thx for reading and i hope you make some suggestions. |
June 17, 2010, 08:23 |
#2 | |
https://openfoam-extend.svn.sourcefo...e/engineValve/ https://openfoam-extend.svn.sourcefo...elEngineValve/ https://openfoam-extend.svn.sourcefo...sSlidingValve/ https://openfoam-extend.svn.sourcefo.../thoboisValve/ in Case you use OpenFOAM (extend/dev) http://repo.or.cz/w/OpenFOAM-1.6.x.g...ne/engineValve if you use OF1.6.x-GIT elvis |
June 18, 2010, 05:27 |
Rep Power: 15 |
Hi thx for your answer.
i am new to OF so i donīt understand those scripts at all. my problem is quite simple, i think. must i really create those scripts or are there any easier ways? or what elements can be copied for this problem? thx for your patience |
June 18, 2010, 05:46 |
#4 | |
If you want to simulate s.th. with a real physical meaning (and behavior of an valve) you should take a deeper look into this stuff. An alternative might be a Boundary Condition that behaves according to your valve but not much easier to implement in my opinion. Are you doing a real world engineering problem or is your stuff going more in the gaming direction? In case of gaming take a look at blender and its cfd capabilaties. Not bad at all! To read more the about the "advanced" stuff you want to do http://web.student.chalmers.se/group...ynamicMesh.pdf At the workshop in Gothenburg the "advanced users" gonna work on OF's dynamic mesh capabilaties that includes valves. Not easy for a beginner! elvis Last edited by elvis; June 19, 2010 at 07:29. |
Large Valve Flow Analysis - Inflation Problem | sercan85 | ANSYS Meshing & Geometry | 2 | June 1, 2010 14:02 |
How to simulate valve with pressure BC? | Luk | FLUENT | 8 | June 20, 2006 08:06 |
Valve action | Hrvoje Jasak (Hjasak) | OpenFOAM Running, Solving & CFD | 0 | January 13, 2005 13:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
