Binary files
Like Tree2Likes
  • 1 Post By alberto
  • 1 Post By olivierG
Old   August 30, 2010, 11:07
Default Binary files
amtri is on a distinguished road
I have 2 separate questions regarding OpenFOAM binary output:
1) Is there a flag in the OpenFOAM file structure that can tell me whether binary data is written in single or double precision?
2) Also, is there a way to tell whether big or little endian is used to write the binary data in the file?
Thanks.
-amtri
amtri is offline   Reply With Quote
Old   September 17, 2010, 01:05
Alberto Passalacqua
Binary files should be written with the precision of the compiled code (double if you use the double precision solver, float if you use the single precision solver), since their purpose is not to lose accuracy when storing data.
OpenFOAM compiles in double precision mode by default.
Best,
Ramzy1990 likes this.
Alberto Passalacqua
Old   March 15, 2011, 04:15
BastiL
bastil is on a distinguished road
Thats true. However, I am looking for a way to save meshes in double precision but run solver in single precision. Therefore, this solver needs to be able to read/write double precision. Has anybody done this before?
Regards Bastian
bastil is offline   Reply With Quote
Old   March 15, 2011, 23:43
Alberto Passalacqua
What is the logic behind this? You would lose the double precision used in the mesh immediately at the first operation you force to be single precision.
Alberto Passalacqua
Old   March 16, 2011, 02:59
BastiL
I will gain a speedup of 40%!
The accuracy differences between SP and DP for my cases are very small.
I can reproduce this behaviour with the ASCII-option: Saving my mesh with 6 digits prevents simpleFoam from running both in SP and DP but saving with 10 digits makes simpleFoam to run in both SP and DP. However SP is about 40% quicker and I don't really want to save in ASCII as it doubles the required diskspace.
Regards Bastian
Old   March 16, 2011, 18:35
Alberto Passalacqua
You can simply save the mesh in compressed format as ASCII, and then switch to binary for the data.
Best,
Alberto Passalacqua
Old   March 17, 2011, 09:01
Olivier
olivierG is on a distinguished road
hello,
On some testcase i did some time ago, with a lot of time step saving, I've got the best speedup with compressed ascii file, binary file where little slower, and ascii file much slower.
so try compressed file !
olivier
lifeinhand likes this.
olivierG is offline   Reply With Quote
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
