[Commercial meshers] Problems with fluent mesh and createpatch
Old   June 28, 2010, 08:52
Default Problems with fluent mesh and createpatch
mauscher is on a distinguished road
hello,
i converted a fluent Mesh in OpenFOAM Mesh. Now I want to create the patches for the inlet, outlet and the walls. So I first created faceSets with the box tools in the faceSetDict and then created patches with these faceSets.
While running the createPatch I get the following message:
Create time
Reading createPatchDict.
Using relative tolerance 0.001 to match up faces and points
Create polyMesh for time = 0
Adding new patch inlet of type empty as patch 2
Read 1508 faces from faceSet inletfaceSet
Doing topology modification to order faces.
Synchronising points.
Points changed by average:0 max:0
Removing patches with no faces in them.
No patches removed.
Attempt to cast type polyMesh to type fvMesh
From function refCast<To>(From&)
in file /home/cluster/cmau/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/typeInfo.H at line 106.
FOAM aborting
Has anyone an idea how to solve this problem?
//Christoph
mauscher is offline   Reply With Quote
Does extrude and createPatch utilities degrade mesh quality? Sashihara OpenFOAM 4 February 11, 2019 16:08
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 06:53
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Salome] unv mesh corrupted after createPatch maddalena OpenFOAM Meshing & Mesh Conversion 1 February 18, 2010 07:43
