how to implement non-Arrhenius reaction rate
Old   June 24, 2010, 19:03
Default how to implement non-Arrhenius reaction rate
Hans
tiddlycorona is on a distinguished road
I wonder how can I implement non-Arrhenius form reaction rate?
For example, the reaction rate of M+N->P+Q is expressed as k=A*f(T), in which T is temperature, and f is an arbitrary function.
Thanks for your help.
tiddlycorona is offline   Reply With Quote
Old   June 25, 2010, 15:35
M. Mahdi Salehi
smehdi609 is on a distinguished road
If it's not an Arrhenius type, then you cannot write it in Chemkin format. Thus, it's not possible to use a Chemkin reader. You should write your own code to calculate the reaction rates. You can still use Chemkin for your thermodynamic model.
smehdi609 is offline   Reply With Quote
Old   January 12, 2018, 06:25
K
mkhm is on a distinguished road
Hello Hans,
I have the same question. Did you find an answer to your question ?
In openFoam, we have three parameters A, beta and Ta which are parameters used to describe a rate coefficient following Arrehnius type reactions. I am wondering if we should change source codes (new solver) in OF in order to be able to use non-arrhenius type rate coefficients.
Best regards
mkhm is offline   Reply With Quote
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 12:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 13:20
surface reaction rate zhou FLUENT 4 October 2, 2003 16:16
Plotting Surface Reaction Rate Ryan FLUENT 0 February 12, 2003 14:47
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
