Boundary conditions: inlet and outlet
Old   May 25, 2010, 09:19
Default Boundary conditions: inlet and outlet
aline is on a distinguished road
Does anyone know where I can find how to use the boundary conditions?
I've looked at the user guide which tells me that a range of BCs are available at src/finiteVolume/fields/fvPatchFields/derived. But I don't know how to use them. I don't understand what goes with what (for example, a specific BC goes with mixed or calculated?).
I'm studying a flow with an inlet (with a definite velocity) and an outlet. I don't know which BC I have to put for these 2 surfaces (inlet and outlet). As there is no gravity in my problem, I guess I should take a BC which fixes the pressure to zero for the outlet, but I don't know which one.
Could anyone help me? thanks a lot in advance.
aline is offline   Reply With Quote
Old   May 26, 2010, 06:06
David
David_010 is on a distinguished road
For the velocity, you can put:
inlet
      type   fixedValue;
      value  uniform (your inlet value, vector);
outlet
        type zeroGradient;
and for the pressure:
inlet
      type   zeroGradient;
outlet
       type   fixedValue;
       value  uniform 0;
These conditions works with laminar regime.
Regards
David
David_010 is offline   Reply With Quote
Old   May 26, 2010, 06:07
David
Repeated post
Old   June 25, 2010, 01:56
trex930 is on a distinguished road
Hey David,
So what happens when you switch to turbulent? Can you keep the same boundary fields??
T
trex930 is offline   Reply With Quote
Old   June 28, 2010, 05:56
NorbertB is on a distinguished road
Hi Foamers,
I have the same question : are you sure it works only in a laminar case, one told me to use such conditions in my turbulent case.
If it does not work in a turbulent case, do you know what kind of boudnary conditions would work so ?
Cheers
PS : Finally those conditions did not work in my DNS case, it gives me a field without any variation ... Help ^^
NorbertB is offline   Reply With Quote
Old   June 28, 2010, 18:00
Default using outlet velocity profile as inlet
Tony
labarc35 is on a distinguished road
Hi All,
Does anyone know how to specify (in COMSOL) an inlet velocity profile from a previously solved model's outlet velocity profile?
I've been trying to create a Fourier Series representation of the profile over time, but I am having trouble doing this with a space and time dimension together.
Any help greatly appreciated. Thank you!
labarc35 is offline   Reply With Quote
Old   June 29, 2010, 03:22
Default To “using outlet velocity profile as inlet”
beauty
beauty is on a distinguished road
Originally Posted by labarc35 View Post
Hi All,
For this, the form provides two ways, one is mapFields, and the other is directMappedPatch. With the former, I mapped the whole field, but not outlet to inlet. Maybe I take a wrong understanding, you can have a try. I mapped the outlet velocity to the inlet using the directMappedPatch boundary. You should change two files:
1. in constant/polyMesh/boundary
inlet
type directMappedPatch;
nFaces #;
startFace #;
offset (0 0 1); // offset (0 0 1) is the distance between the inlet and the outlet
sampleMode nearestPatchFace;
samplePatch outlet;
2. in 0/U
inlet
type directMappedFixedValue;
value (0 0 0);
setAverage true;
average (0 0 2);
Then you can check whether you want results.
beauty is offline   Reply With Quote
Old   June 29, 2010, 03:45
Default problem with boundary
beauty
I also have problems on defining the bounary. For pressure, when using zeroGradient for inlet, everything goes well. After changing zeroGradient to calculated, I get this message:
valueInternalCoeffs cannot be called for a calculatedFvPatchField
on patch inlet of field p in file "/home/flow/OpenFOAM/flow-1.6/run/pipe/tphase/ke/0/p"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::valueInternalCoeffs( const tmp<scalarField>&) const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 145.
can anyone tell us how to use the boundary conditions?
Thanks
beauty
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
