Functions to import non grid associated experimental data
Old   June 29, 2010, 12:04
Default Functions to import non grid associated experimental data
Ben K
benk is on a distinguished road
I have some experimental data for a diffusion coefficient that depends on temperature and concentration. It's difficult to fit this data to polynomial functions and so what I want to do is import this data into my solver and then along with calculated concentration/temperatures, populate a volScalarField using the data along with an interpolation routine.
Has anybody done this and/or are there built-in functions in OpenFOAM to do this?
benk is offline   Reply With Quote
Old   June 30, 2010, 05:11
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Maybe someone can highlight how to use foam's interpolation routines, but I had to do something similar and just used the STL. I've attached a linear interpolator with a driver routine, let me know if there are problems. I guess for your case you'll have to just call the interpolator twice, once against temperature and then against concentration.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Tecplot. add experimental data into a mesh Alejandro FLUENT 0 December 10, 2008 07:08
Experimental data on transition kepler Main CFD Forum 2 October 24, 2007 03:13
Looking for the experimental data COLOPOLO Main CFD Forum 2 January 28, 2004 23:38
Availability of experimental combustion data? Mario Main CFD Forum 3 September 23, 2003 11:05
Grid refinement with wall functions Mark Render Main CFD Forum 8 May 2, 2000 07:09
