June 16, 2010, 05:08 |
Turbulent combustion error... XiFoam model
achinta
Rep Power: 16 |
I am working on Gas turbine combustion simulation. I tried to use XiFoam model. The following error was displayed. ------------------------------------------- Create time Create mesh for time = 0 Reading combustion properties Ignition switched off Reading g Reading thermophysical properties Selecting thermodynamics package hhuMixtureThermo<homogeneousMixture<sutherlandTran sport<specieThermo<janafThermo<perfectGas>>>>> min(b) = 1 Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model LaunderSharmaKE LHS and RHS of + have different dimensions dimensions : [0 0 0 0 0 0 0] + [-1 3 0 0 0 0 0] #0 Foam::error:rintStack(Foam::Ostream&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam:perator+(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator+<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/XiFoam" #4 Foam::compressible::RASModels::LaunderSharmaKE::fM u() const in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #5 Foam::compressible::RASModels::LaunderSharmaKE::La underSharmaKE(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #6 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::Launder SharmaKE>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #7 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #8 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::RASMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so" #9 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so" #10 main in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/XiFoam" #11 __libc_start_main in "/lib64/libc.so.6" #12 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function operator+(const dimensionSet& ds1, const dimensionSet& ds2) in file dimensionSet/dimensionSet.C at line 403. FOAM aborting -------------------------------------------- There is a problem with dimensions. I am not able to locate it as I am new to OpenFOAM. Could someone please locate the problem? Thank you, Regards, Achinta |
July 7, 2010, 08:24 |
Danilo
Rep Power: 17 |
you did an error in the input dimensions!
a typical case is when you copy the Bc from an incompressible case to a compressible one.. in these two cases the pressures are measured in a different way (one is scaled by the density). i hope i helped you! cheers Danilo |
Weller combustion model - engineFoam solver. | ghindi | OpenFOAM Running, Solving & CFD | 1 | May 6, 2016 05:56 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
Clarification on a combustion model. | ShyamSundar | FLUENT | 0 | September 2, 2005 06:16 |
NOx Formation in Turbulent hydrogen combustion | Ali Yigit | FLUENT | 1 | December 22, 2003 03:50 |
Combustion model in Diesel Engines | roadracer | Siemens | 1 | May 13, 2003 10:05 |
