Thermophysical models and chemistry models
Old   July 8, 2010, 15:44
Exclamation Thermophysical models and chemistry models
Hassan Kassem
hk318i is on a distinguished road
Dear Foamers,
I am modifying rhoReactingFoam solver (OpenFOAM 1.6). I want implement Eddy break-up model. I have no problem with the reaction rate. My main problem is the energy equation source term. I need to access the specieThermo to get Hc() (I think it is the enthalpy of formation).
I cannot access it. I think, I am not understand how to access the thermophysical and chemistry models.
How are the thermophysical and chemistry models implemented in the solve? How can I access it?
hk318i is offline   Reply With Quote
Old   July 9, 2010, 04:18
Christian Lucas
Chris Lucas is on a distinguished road
Hi hk318i,
I'm not sure if this answers your question because I'm not sure where you need the thermophysical properties (e.g. the solver or the chemistry model template)
In the solver (as an expample I use rhoSimpleFoam, where hPsiThemro is used), the thermophsyical model is loaded in the "createFields.H" file. The imported lines are:
Info<< "Reading thermophysical properties\n" << endl;
autoPtr<basicPsiThermo> pThermo
basicPsiThermo::New(mesh)
basicPsiThermo& thermo = pThermo();
now lets say you want to get the enthalpy so the function is: "your variable = thermo.h();"
This function can be found in the file (OpenFoam/src/thermophysicalModels/basic/psiThemro/hPsiThemro.H). The function is
virtual const volScalarField& h() const
return h_;
These functions could also be in the following files: "basicThemro.H" and "psiBasicThermo.H".
So, if you need to get hc in the solver, you first have to make sure that a function like the one above (of course for hc) exist in your themrophysical model.
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   July 9, 2010, 05:26
marcbest is on a distinguished road
hi chris
i've a question to your reply:
is it: yourvariable = thermo.h(); or: yourvariable = thermo.h_(); (with underscore like below?
return h_;
and must i include:
#include basicPsiThermo
at the beginning?
thanks for your help
regards marc
marcbest is offline   Reply With Quote
Old   July 9, 2010, 06:19
Christian Lucas
Hi Marc
the correct term is "volScalarField& h = thermo.h();" (Have a look at the source code of rhoSimpleFoam). The other possibility that might work is:
"volScalarField& h = thermo.h_;". However, I think the variable h_ is protected, so it won't work.
h_ is the variable(field) used in the thermophysicalProperties and the function h() simply returns h_.
You have to include " #include "basicPsiThermo.H" ". In the case of rhoSimpleFoam, you can find the line in the file "rhoSimpleFoam.C"
Regards,
Christian
Old   July 9, 2010, 06:21
Hassan Kassem
Dear Chirs,
rhoReactingFoam uses chemistry model not a thermophysical model as the following;
Info<< nl << "Reading thermophysicalProperties" << endl;
autoPtr<rhoChemistryModel> pChemistry
rhoChemistryModel::New(mesh)
rhoChemistryModel& chemistry = pChemistry();
hsReactionThermo& thermo = chemistry.thermo();
the variable which I am looking for is specieThermo.Hc()
my the Thermophysicalproperties is
thermoType hsRhoMixtureThermo<reactingMixture<gasThermoPhysic s>>;
my chemistryproperties is
rhoChemistryModel ODEChemistryModel<gasThermoPhysics>;
I have no idea what is gasThermoPhysics?
Thanks
Old   July 9, 2010, 09:40
hi hassan,
as i understood chemistry is a part of thermophysicalModels, because you need alway a "...Thermo"-file to get T,p, h, etc..
And in the file rhoReactingFoam.C there is
#include "hReactionThermo.H"
used, which then actually returns hc()
00134 //- Chemical enthalpy [J/kg]
00135 virtual tmp<volScalarField> hc() const = 0;
so you can use this
regards marc
Old   July 9, 2010, 10:06
Hassan Kassem
Dear Marc,
my hReactionThermo.H member functions as the following;
// Member functions
//- Return the composition of the multi-component mixture
virtual basicMultiComponentMixture& composition() = 0;
virtual const basicMultiComponentMixture& composition() const = 0;
// Access to thermodynamic state variables
//- Enthalpy [J/kg]
// Non-const access allowed for transport equations
virtual volScalarField& h()
return h_;
//- Enthalpy [J/kg]
return h_;
//- Update properties
virtual void correct() = 0;
I cannot find hc(). Actually all I need to access the enthalpy of formation to make the energy equ source term which is a function of reaction rate (which I calculated based on my model) and specie enthalpy of formation (like Hc() in specieThermo)
Regards Hassan
Old   July 9, 2010, 14:42
M. Mahdi Salehi
smehdi609 is on a distinguished road
Just a quick note:
In reactingFoam, a transport equation for "total enthalpy " is solved. Total enthalpy is the sensible enthalpy plus the chemical enthalpy. Thus, the transport equation for this variable does not contain any chemical reaction source term, it is conserved in an adiabatic flame. The chemical reaction source terms are provided for the species mass fractions. Once you get the species mass fractions, the "thermo->correct();" method will calculate the heat of formation and desctruction of different species.
smehdi609 is offline   Reply With Quote
Old   July 9, 2010, 14:53
Hassan Kassem
I am using OpenFOAM 1.6 which reactingFoam and rhoReactingFoam solve transport equation for sensible enthalpy not the total enthalpy.
Do you think I should use transport equation for total enthalpy instead of sensible enthalpy?
Old   July 9, 2010, 14:59
M. Mahdi Salehi
This is the hEqn.h in reactingFoam in Openfoam1.6:
fvScalarMatrix hEqn
fvm::ddt(rho, h)
+ mvConvection->fvmDiv(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
DpDt
hEqn.relax();
hEqn.solve();
thermo.correct();
I do not see any source term, I do not think that it solves for sensible enthalpy, are you sure?
Old   July 9, 2010, 15:10
Hassan Kassem
My version uses hs with source term as the following;
fvScalarMatrix hsEqn
fvm::ddt(rho, hs)
+ mvConvection->fvmDiv(phi, hs)
- fvm::laplacian(turbulence->alphaEff(), hs)
DpDt
+ chemistrySh
hsEqn.relax();
hsEqn.solve();
thermo.correct();
Info<< "T gas min/max = " << min(T).value() << ", "
<< max(T).value() << endl;
I am using OpenFoam1.6.x which I think it is like OpenFoam 1.7 use sensible enthalpy instead of total enthalpy
Old   July 9, 2010, 15:18
M. Mahdi Salehi
yes, I downloaded openfoam1.7 and I see now ! it's great, they finally make this. I needed this ! Thanks
Old   July 9, 2010, 15:28
Hassan Kassem
Actually I am little bit confused about using chemistry and thermophysical models. How can I access the data? How can I change the model inside the solver? and what is the "Selector" ? :-O
Old   July 9, 2010, 16:59
M. Mahdi Salehi
For "selecting" you may read this:
http://openfoamwiki.net/index.php/Op...tion_mechanism
You cannot have access to everything, unless you change the source code for thermo and chemistry objects. However, you have access to reaction rates, heat release, ... .
Old   July 9, 2010, 17:19
Hassan Kassem
so I cannot access to something like enthalpy of formation of each specie.
Old   July 11, 2010, 11:31
hut
Anh Le
hut is on a distinguished road
Hi everyone,
I am trying to simulate a incompressible, laminar fluid flow model with adding temperature field. I used air to be the inlet gas. Assuming that "basicPsiThemo" is only used for compressible, turbulence flow, hence I want to use "basicThermo" model only. And I was writing into the "createFields.H" like that:
line 1 Info<< "Reading thermophysical properties\n" << endl;
line 2
line 3 autoPtr<basicThermo> pThermo
line 4 (
line 5 basicThermo::New(mesh)
line 6 );
line 7 basicThermo& thermo = pThermo();
line 8 volScalarField& h = thermo.h(); ...
And then compile the code. An error is shown:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:5: error: no matching function for call to ‘Foam::dictionary::New(Foam::fvMesh&)’
/home/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/dictionary.H:218: note: candidates are: static Foam::autoPtr<Foam::dictionary> Foam::dictionary::New(Foam::Istream&)
So what is the right one I have to declare? What does it mean about the line 5? And how can I check the declaration of basicThermo mode?
Please give me a hint?
hut is offline   Reply With Quote
Old   July 12, 2010, 08:32
Hassan Kassem
Dear Anh,
I am new OpenFoam user and I am not fully aware about this problem.
As I know you cannot basicThermo like as you mentioned because basicThermo class does not have a selector function like basicpsiThermo.
Old   July 12, 2010, 15:08
hut
Anh Le
Originally Posted by hk318i View Post
Dear Anh,
Thanks. I got that. However, what is basicThermo function to use? Can basicpsiThermo quantities be used for incompressible, laminar flow? If not, what is the right one?
Old   July 12, 2010, 15:47
Hassan Kassem
you can check the openFoamwiki below likw which descripe how to add temperature to icoFoam solver.
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Old   July 15, 2010, 06:09
Hassan Kassem
Dear All,
Anyone knows what is the CompType in ODEChemistryModel and other chemistry models?
I am still looking how to access the enthalpy of formation of each species. any ideas?
Regards,
Hassan
Equilibrium Reaction Rates/Gas Chemistry Greg Perkins FLUENT 6 January 6, 2017 02:59
