Can't convert my mesh created in Gmsh to OpenFOAM
Old   May 2, 2018, 04:28
Post Can't convert my mesh created in Gmsh to OpenFOAM
Crystal
Crystal 95 is on a distinguished road
Hi everyone!
My name is Crystal and I have an issue in converting the mesh that I created in Gmsh to OpenFoam.
I have tried using th commands "gmshToFoam Part2.msh" and also "fluentMeshToFoam Part2.msh" but they keep saying error.
I'm currently using Gmsh version 2.11.0 (64bit Linux) and OpenFOAM-in-Box-18.02.
I'm open to any suggestions or solutions so please feel free to help me out or ask me any questions for any clarification.
Here are the attached file:
Crystal 95 is offline   Reply With Quote
Old   May 2, 2018, 10:42
clapointe is on a distinguished road
Can you post the error (or the full case, and not just the .msh file)? I've used gmshToFoam recently for OF4x and gmsh2.12 and it worked fine. The key is to check the boundaries in constant/polyMesh/boundaries to make sure that they're correct -- if I recall correctly they were all changed to "patch" type by the converter.
Caelan
clapointe is offline   Reply With Quote
gmsh to openfoam
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[Other] how to convert a mesh drawn in matlab to a format which can be used in OpenFOAM jali OpenFOAM Meshing & Mesh Conversion 3 July 19, 2017 20:16
Importing Mesh from GMsh to OpenFoam bmaldi OpenFOAM Running, Solving & CFD 1 May 4, 2016 11:57
[Other] Error while tring to convert mesh generated in salome to openfoam Arjun Jayakumar OpenFOAM Meshing & Mesh Conversion 0 October 10, 2014 08:46
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
