cavity case with different mesh
Old   July 17, 2010, 15:43
Default cavity case with different mesh
anonymous
masterfgee is on a distinguished road
hi fellow foamers,
i am trying to simulate a case very similar to the lid driven cavity tutorial. in my mesh the two sides have an angel of 4° between them and the top wall is an arc with the radius of 4 and the bottom wall is an arc with the radius of 3. like in the tutorial case, the top wall moves but here it rotates around the z axis. unfortunately the results with icoFoam look very weird. i am not sure what the problem is but i thought my results should look like the one in the cavity tutorial. i would really appreciate it if someone could take a look and post his/her thoughts
cheers
masterfgee is offline   Reply With Quote
Old   July 21, 2010, 11:53
marcbest is on a distinguished road
hi masterfgee,
i've never used the rotatingWallVelocity yet.
top
type rotatingWallVelocity;
origin (0 0 0);
axis (1 0 0);
omega 0.1; // omega * radius = 0.1 * 0.004 = 0.0004 m/s
value uniform (0 0 0);
but is it really important that you have these radii or can you omit them? perhaps you can try without the radii and compare the results...
marcbest is offline   Reply With Quote
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Turotial cavity: Mapping mesh bego OpenFOAM 0 January 14, 2010 05:23
Errors during execution of tutorial case with own mesh sergey OpenFOAM Running, Solving & CFD 0 May 18, 2007 03:15
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Oscillating Residuals in Finer Mesh Case Jake FLUENT 3 June 16, 2005 09:34
