running in parallel, at time t>0
Old   September 1, 2010, 17:14
Default running in parallel, at time t>0
bunni is on a distinguished road
I'm running a simulation in parallel, but I need to do it in two parts with a change in BC, and solver, etc.
So, the first bit is easy, I use:
deconstructPar
run solver in parallel
reconstructPar -latestTime
run specially written function, changes bc, etc. Now at time latestTime+0.1
My question is how to cast the information of bc, pressures, new U etc at latestTime+0.1 back to all my deconstructed directories, so I can run:
newsolver in parallel
I couldn't find this answer, but I'm not quite sure what to look for, so thanks for help.
bunni is offline   Reply With Quote
Old   October 21, 2010, 09:34
Vishal Jambhekar
vishal is on a distinguished road
Hi all,
i decomposed the mesh ran it in parallel and while doing
reconstructPar -latestTime or reconstructPar i am facing following error.
Please help me in this context.
Create time
Create mesh for time = 1
Time = 6.5
Reconstructing FV fields
Reconstructing volScalarFields
p
Reconstructing volVectorFields
U
Reconstructing surfaceScalarFields
phi
No point fields
No lagrangian fields
--> FOAM FATAL ERROR:
Couldn't create directory "/home/vj/OpenFOAM/vj-1.7.1/TrnasProjs/WInd_Tun_1/6.5/uniform"
From function Foam::mkDir(const fileName&, mode_t)
in file POSIX.C at line 422.
FOAM exiting
[vj@hanuta WInd_Tun_1]$ reconstructPar -latestTime
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
parallel decomposepar
User fortran error when running CFX-10 in parallel CFDworker CFX 3 September 22, 2015 08:59
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Running in parallel Rasmus Gjesing (Gjesing) OpenFOAM 35 March 31, 2011 18:21
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 17:16
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 08:52
