July 28, 2010, 04:52 |
Changing orientation of object in Paraview
Jochem
Rep Power: 15 |
I have some problems with the orientation of an stl. file loaded into my case. I want to simulate an airflow trough a build environment, and i want to use the dominant wind direction. When i load the stl file in paraview, the object has a fixed orientation. I've tried to rotate the blockmesh to simulate a certain wind direction but the problem is that my snappyHexMesh doesn't rotate with the blockMesh. So the snappyHexMesh and the blockMesh are not parallel. Does somebody can help me changing the orientation in Paraview or changing the direction of the snappyHexMesh (perhaps with a rotation of the mesh)? Regards, Jochem |
[OpenFOAM] How to draw a time changing vector in paraview | bigphil | ParaView | 0 | December 5, 2009 09:28 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
