August 9, 2010, 16:51 |
Resolving Velocity Magnitudes with Probes
Rep Power: 15 |
Hi again. I wish to use OpenFOAM to calculate velocity magnitudes in the flow field with respect to time however I have only been able to code for the two respective points below to resolve the u, v and w components which I would rather not have to post-process. I think that the magnitudes need to be calculated and then magU used but I haven't seen this explicitly coded elsewhere on some google searches. Any help would be appreciated, if I haven't explained myself clearly enough then let me know!
Thanks. Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.02; deltaT 0.0001; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 12; writeCompression uncompressed; timeFormat general; timePrecision 12; runTimeModifiable yes; libs ( "libOpenFOAM.so" "libgroovyBC.so" ) ; functions { probes { type probes; functionObjectLibs ("libsampling.so"); enabled true; outputControl timeStep; outputInterval 10; probeLocations ( ( 1 10 0.5 ) ( 2 2 0.5 ) ); fields ( U ); } } |
Unbelievably high velocity magnitudes in film cooling - HELP! | shankara.2 | FLUENT | 0 | June 1, 2009 22:43 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 24, 2006 23:09 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
