bubbleFoam validation case
Old   August 19, 2010, 07:05
Default bubbleFoam validation case
Balkrishna Patankar
balkrishna is on a distinguished road
I faced the following difficulty.
I switch off the dispersed phase volume fraction at inlet . That is inlet alpha = uniform 0 and also the dispersed phase velocity . I keep my continuous phase velocity Ub = 0.1 m/s . Continuous properties are rho = 1000 kg/m3 , nu = 1e-06 m2/s . This means now i am studying single phase flow . I compared the results to simpleFoam results and have found a problem with the velocity plots in the plane z=0.2 on the same timestep . Specifically on the line joining (0 0.5 0.2) and (1 0.5 0.2) . Can someone help me resolve this issue ....
My blockMeshDict is as follows :
/*--------------------------------*- C++ -*----------------------------------* \
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
 (0 0 0)
 (0.25 0 0)
 (0.25 0.25 0)
 (0 0.25 0)
 (0 0.75 0)
 (0.25 0.75 0)
 (0 1 0)
 (0.25 1 0)
 (0.75 0 0)
 (0.75 0.25 0)
 (1 0 0)
 (1 0.25 0)
 (0.75 0.75 0)
 (1 0.75 0)
 (0.75 1 0)
 (1 1 0)
 (0 0 2)
 (0.25 0 2)
 (0.25 0.25 2)
 (0 0.25 2)
 (0 0.75 2)
 (0.25 0.75 2)
 (0 1 2)
 (0.25 1 2)
 (0.75 0 2)
 (0.75 0.25 2)
 (1 0 2)
 (1 0.25 2)
 (0.75 0.75 2)
 (1 0.75 2)
 (0.75 1 2)
 (1 1 2)
blocks
 hex (0 1 2 3 16 17 18 19) (10 10 10) simpleGrading (1 1 1)
 hex (3 2 5 4 19 18 21 20) (10 10 10) simpleGrading (1 1 1)
 hex (4 5 7 6 20 21 23 22) (10 10 10) simpleGrading (1 1 1)
 hex (1 8 9 2 17 24 25 18) (10 10 10) simpleGrading (1 1 1)
 hex (2 9 12 5 18 25 28 21) (10 10 10) simpleGrading (1 1 1)
 hex (5 12 14 7 21 28 30 23) (10 10 10) simpleGrading (1 1 1)
 hex (8 10 11 9 24 26 27 25) (10 10 10) simpleGrading (1 1 1)
 hex (9 11 13 12 25 27 29 28) (10 10 10) simpleGrading (1 1 1)
 hex (12 13 15 14 28 29 31 30) (10 10 10) simpleGrading (1 1 1)
edges
patches
 patch inlet (
	      (2 5 12 9)
 patch outlet (
	       (16 19 18 17)
	       (19 20 21 18)
	       (20 22 23 21)
	       (17 18 25 24)
	       (18 21 28 25)
	       (21 23 30 28)
	       (24 25 27 26)
	       (25 28 29 27)
	       (28 30 31 29)
   wall fixedWalls
     (0 16 19 3)
     (3 19 20 4)
     (4 20 22 6)
     (6 22 23 7)
     (7 23 30 14)
     (14 30 31 15)
     (15 31 29 13)
     (13 29 27 11)
     (11 27 26 10)
     (10 26 24 8)
     (8 24 17 1)
     (1 17 16 0)
     (0 3 2 1)
     (3 4 5 2)
     (4 6 7 5)
     (5 7 14 12)
     (12 14 15 13)
     (9 12 13 11)
     (8 9 11 10)
     (1 2 9 8)
mergePatchPairs
The velocity plots are on this page .... https://sites.google.com/site/balkrishnanitt/
balkrishna is offline   Reply With Quote
bubble, bubblefoam, foam
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 05:43
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 13:18
Validation Case Ruben Main CFD Forum 0 November 1, 2005 10:50
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:03
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:02
