Unstable spray for small mesh size (dieselFoam) |
August 13, 2010, 14:11 |
I could not figure out the reasons for the water spray in my simulation becoming unstable when I make the mesh size smaller. I hope the community can point me in a direction for diagnosing this issue. I have included a video for your viewing. If you need the files, I can post them also. The mesh size is 2.5 cm x 2.5cm x 2.5cm. Following is my set up: + dieselFoam for water spray (10 micron min and 50 micron max droplet dia) + nozzle dia = 3 mm + injection velocity = 10 m/sec + mass flow rate = 0.04241 kg/sec + injection pressure = ~1.5 bar + room size = 4 m long x 2 m high x 2 m wide with ambient air temp (300K ) and ambient pressure I used VirtualDub (free and portable video editing software) to compress and crop the file. Thank you for your help.
Nam Last edited by namCFD; August 13, 2010 at 14:34. |
August 13, 2010, 15:43 |
more parcels
David P. Schmidt
Without looking at your case in detail, I have a suggestion. You need to greatly increase the number of computational parcels injected into your domain (this doesn't change the injected mass, but rather represents the mass with a greater statistical fidelity).
The reason is that, as a cell gets smaller, the source terms of cells in densely loaded regions get hit with huge noisy source terms from the droplets at are proportionately larger. At a minimum, you want the number of parcels to go up proportional to the cell count. Even that is not really sufficient. See: David P. Schmidt, “Theoretical Analysis for Achieving High-Order Spatial Accuracy in Lagrangian/Eulerian Source Terms,” Int. J. of Numerical Methods in Fluids, 52(8), 2006. and slightly related: Sasanka Are, Shuhai Hou, David P. Schmidt, “Second Order Spatial Accuracy in Lagrangian-Eulerian Spray Calculations,” Numerical Heat Transfer, Part B: Fundamentals, 48(1), pp. 25-44, 2005. -DPS |
August 13, 2010, 15:51 |
#3 | |
Nam |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Help with fixing imported IGES model | siw | ANSYS Meshing & Geometry | 24 | August 24, 2010 11:22 |
unstructure mesh size control near to wall using gambit | lalit kumar | FLUENT | 4 | July 6, 2010 15:13 |
Gambit Unstructed (Tet) Mesh - size control | newbie | FLUENT | 3 | August 26, 2008 11:38 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
