August 27, 2010, 15:35 |
courant number
Dear Foamers,
What is the meaning of Co number in the pisoFoam for example. what should be its range? is it important in implicit methods? i know it is for stability. how much it can be large? please talk about the role and magnitude of this number in solving methods. Regards, Maysam |
August 30, 2010, 02:13 |
Anton Kidess
Rep Power: 29 |
Read Peric or Patankar about the PISO method and you will see assumptions are made that require a Courant number limit. This is independent of the implicit / explicit time marching scheme. For an incompressible flow you should get away with Co < 1, but there are cases (eg. VOF) that may require an even tighter criterion to produce nicer results.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
