Steady state multi species
Old   September 16, 2010, 05:41
Default Steady state multi species
Hrushikesh Khadamkar
Hrushi is on a distinguished road
Hi, I am trying to develop liquid phase multi species solver with/without reaction (no combustion).
Can anybody explain me how to define species, species properties in OpenFOAM?
How to create lookup table for species so that each species is assigned some number?
So that I can solve the transport equation for each species like that done in Yeqn.H code in reactingFoam solver.
Mass fraction given by the above YEqn can then be used to calculate mass weighted average mixture properties like:
rhomix = rho1*Y[1] + rho2*Y[2] + rho3*Y[3]
This average mixture properties then can be used to solve the momentum equation.
Reaction effect can be introduced by adding the source term in Yeqn.H later on.
Any suggestions , Please...
Hrushi is offline   Reply With Quote
Old   September 16, 2010, 08:27
marcbest is on a distinguished road
as a beginnig you can use this report http://projekter.aau.dk/projekter/fi...784/Report.pdf
marcbest is offline   Reply With Quote
Old   September 27, 2010, 05:06
Default individual species properties in for loop to calculate rho_mix and nu_mix
hi,
I would like to use mixture viscosity in the solving momentumm equation. For that I need to calculate mixture density (mass weighted). From that I can calculate mixture kinematic viscosity (nu_mix) . To do this, I need access to species mass fraction, species density, species viscosity.
rho_mix = rho1*Y[1]+rho2*Y[2]+rho3*Y[3]
nu_mix= (rho1*nu1*Y[1]+rho2*nu2*Y[2]+rho3*nu3*Y[3])/rho_mix
My question is how can I call individual species properties in for loop to calculate rho_mix and nu_mix?
for (lable i=0, i<Y.size(),i++)
rho_mix=rho_mix+rho1*Y[i]+rho2*Y[i]+rho3*Y[i]
Old   September 27, 2010, 09:09
Cyp
Cyprien
Cyp is on a distinguished road
hi Hrushi!
I think you should defined your rho1,rho2,rho3 as a list of scalar : rho=(rho1,rho2,rho3)
hence, rho[0]=rho1 ; rho[1|=rho2 ;rho[2]=rho3
and you can use the following loop :
rho_mix=0.0
for (int i=0; i<Y.size(); i++)
     rho_mix=rho_mix+rho[i]*Y[i];
else, you can define your mixture density as :
rho_mix = rho1*Y[0] + rho2*Y[1] + rho3*Y[2]
(keep in mind that C++ starts the numerotation from 0)
Cyp is offline   Reply With Quote
Old   October 24, 2010, 08:03
Default error: no match for 'operator='
Hi Cyprien,
I have tried your suggestion. But when I compile the code, I get the following error message.
SOURCE=simpleMyFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/RASModel -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/transportModels -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/transportModels/incompressible/singlePhaseTransportModel -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/export/apps/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/simpleMyFoam.o
In file included from simpleMyFoam.C:66:
YEqn.H:21: warning: left-hand operand of comma has no effect
YEqn.H:21: warning: right-hand operand of comma has no effect
YEqn.H:21: error: no match for 'operator=' in 'rho = (0, rho3)'
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:447: note: candidates are: void Foam::List<T>perator=(const Foam::UList<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:479: note: void Foam::List<T>:perator=(const Foam::List<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:494: note: void Foam::List<T>:perator=(const Foam::SLList<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:522: note: void Foam::List<T>:perator=(const Foam::IndirectList<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:541: note: void Foam::List<T>:perator=(const Foam::UIndirectList<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/List.C:560: note: void Foam::List<T>:perator=(const Foam::BiIndirectList<T>&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/ListI.H:134: note: void Foam::List<T>perator=(const T&) [with T = double]
/export/apps/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: warning: unused variable 'momentumPredictor'
/export/apps/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: warning: unused variable 'fluxGradp'
/export/apps/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readSIMPLEControls.H:12: warning: unused variable 'transonic'
make: *** [Make/linux64GccDPOpt/simpleMyFoam.o] Error 1
The error repeats for line 41 and 61 also.
Here is my YEqn.H:
/*tmp<fv::convectionScheme<scalar> > mvConvection
fv::convectionScheme<scalar>::New
mesh,
fields,
phi,
mesh.divScheme("div(phi,Yi_h)")
label inertIndex = -1;
volScalarField Yt = 0.0*Y[0];
const dimensionedScalar& rho1 = speciesProperties.lookup("rho1");
const dimensionedScalar& rho2 = speciesProperties.lookup("rho2");
const dimensionedScalar& rho3 = speciesProperties.lookup("rho3");
List <scalar> rho(3);
rho = (rho1,rho2,rho3);
volScalarField rho_mix
IOobject
"rho_mix",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
mesh
const dimensionedScalar& mu1 = speciesProperties.lookup("mu1");
const dimensionedScalar& mu2 = speciesProperties.lookup("mu2");
const dimensionedScalar& mu3 = speciesProperties.lookup("mu3");
List <scalar> mu(3);
mu = (mu1,mu2,mu3);
volScalarField mu_mix
IOobject
"mu_mix",
runTime.timeName(),
mesh,
mesh
const dimensionedScalar& nu1 = speciesProperties.lookup("nu1");
const dimensionedScalar& nu2 = speciesProperties.lookup("nu2");
const dimensionedScalar& nu3 = speciesProperties.lookup("nu3");
List <scalar> nu(3);
nu = (nu1,nu2,nu3);
for (label i=0; i<Y.size(); i++)
if (Y[i].name() != inertSpecie)
volScalarField& Yi = Y[i];
solve
fvm::div(phi,Yi)
// mvConvection->fvmDiv(phi, Yi)
- fvm::laplacian(turbulence->nuEff(), Yi)
source_r
Yi.max(0.0);
Yt += Yi;
rho_mix += rho [i] * Yi;
mu_mix += mu [i] * Yi;
else
inertIndex = i;
Y[inertIndex] = scalar(1) - Yt;
Y[inertIndex].max(0.0);
rho_mix += rho[inertIndex] * Y[inertIndex];
mu_mix += mu[inertIndex] * Y[inertIndex];
volScalarField nu_mix
IOobject
"nu_mix",
runTime.timeName(),
mesh,
mu_mix/rho_mix
I am not able to understand the error message. I tried to look into list.H and list .C but could not get the clue.
Can you (anyone) please help me out in how to define the list of scalars and their assignment?
Thanks and Regards,
Hrushikesh
Old   October 24, 2010, 14:54
Cyp
Cyprien
did you try ptrList instead of List ?
Old   October 27, 2010, 06:24
Default Error while execution
I have modified the simpleFoam solver. I have included specie equation. The code compiles giving no compliation error. But when I run my code, it gives following error message:
Create time
Create mesh for time = 0
Reading thermophysicalProperties
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
alphaEps 0.76923;
sigmaEps 1.3;
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.000312273, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.000245102, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.779043, Final residual = 0.000142658, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00865508, No Iterations 87
time step continuity errors : sum local = 0.00383834, global = 3.55093e-06, cumulative = 3.55093e-06
DILUPBiCG: Solving for epsilon, Initial residual = 0.868617, Final residual = 0.0142968, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0286599, No Iterations 1
hanging pointer, cannot dereference#0 Foam::error:rintStack(Foam::Ostream&) in "/export/apps/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/export/apps/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 main in "/home/na16116/run/run/simpleMyFoam/bin"
#3 __libc_start_main in "/lib64/libc.so.6"
#4 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/na16116/run/run/simpleMyFoam/bin"
From function PtrList:perator[]
in file /export/apps/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/PtrListI.H at line 123.
FOAM aborting
Abort
Can anyone explain what is the reason for this error message?
Thanks
Hrushikesh
Old   October 28, 2010, 06:02
Default Hanging pointer error
Here are the details of my case:
createFields.H
Info<< nl << "Reading thermophysicalProperties" << endl;
PtrList<volScalarField> Y(5);
IOdictionary speciesProperties
IOobject
"speciesProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
wordList speciesNames
speciesProperties.lookup("speciesNames")
//speciesTable (speciesNames);
dimensionedScalar source_r
speciesProperties.lookup("source_r")
word inertSpecie(speciesProperties.lookup("inertSpecie" ));
Info << "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
mesh
Info << "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
# include "createPhi.H"
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("SIMPLE"), pRefCell, pRefValue);
singlePhaseTransportModel laminarTransport(U, phi);
autoPtr<incompressible::RASModel> turbulence
incompressible::RASModel::New(U, phi, laminarTransport)
YEqn.H
mesh,
fields,
phi,
const dimensionedScalar rlist[3] = {rho1,rho2,rho3};
/*FixedList<dimensionedScalar,3> FixedRList(rlist);
List <dimensionedScalar> rho(FixedRList);*/
IOobject
"rho_mix",
runTime.timeName(),
mesh,
mesh
const dimensionedScalar mulist[3] = {mu1,mu2,mu3};
/*FixedList<dimensionedScalar,3> FixedMuList(mulist[3]);
List <dimensionedScalar> mu(FixedMuList);*/
IOobject
"mu_mix",
runTime.timeName(),
mesh,
mesh
/*const dimensionedScalar& nu1 = speciesProperties.lookup("nu1");
const dimensionedScalar nulist[3] = {nu1,nu2,nu3};
FixedList<dimensioned<double>,3> FixedNuList(nulist);
List <dimensionedScalar> nu(FixedNuList);*/
solve
fvm::div(phi,Yi)
source_r
Yi.max(0.0);
Yt += Yi;
rho_mix += rlist [i] * Yi;
mu_mix += mulist [i] * Yi;
else
inertIndex = i;
//rho_mix += rlist[inertIndex] * Y[inertIndex];
//mu_mix += mulist[inertIndex] * Y[inertIndex];
IOobject
"nu_mix",
runTime.timeName(),
mesh,
mu_mix/rho_mix
simplemyFoam.C
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 1991-2009 OpenCFD Ltd.
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software; you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the
Free Software Foundation; either version 2 of the License, or (at your
option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM; if not, write to the Free Software Foundation,
Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Application
simpleFoam
Description
Steady-state solver for incompressible, turbulent flow
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "RASModel.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "readSIMPLEControls.H"
#include "initConvergenceCheck.H"
p.storePrevIter();
// Pressure-velocity SIMPLE corrector
#include "UEqn.H"
#include "pEqn.H"
turbulence->correct();
#include "YEqn.H"
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
#include "convergenceCheck.H"
Info<< "End\n" << endl;
return 0;
The code compiles. But it crashes when executing during 1st iteration with hanging pointer error described in previous reply.
Any suggestions please
Hrushikesh
Old   November 2, 2010, 10:09
Cyp
Cyprien
createFields.H
Is it normal that you have Y(5) instead of Y(3) ??
Old   November 2, 2010, 23:13
Yes, it doesnot make any difference. The problem lies in how to fill up the ptrList? I looked at ptrList code. The set function is used for the same.
I am trying with that now. Do you know the correct way/alternate way to fill up the ptrList?
Hrushi
Old   November 3, 2010, 01:34
Nakul
nakul is on a distinguished road
Hi Hrushi,
I am also trying to implement something similar. Can you tell me what thermodynamics package you are using for your mixture in your thermoPhysicalProperties dictionary?
I am using hsCombustionThermo with "multiComponentmixture" but I am not being able to get it right.
There is no example as to how multiple species are read by OpenFOAM while using multicomponent mixture.
Could you also tell how are you reading in the multiple species of the mixture?
Thanx
nakul is offline   Reply With Quote
Old   November 14, 2010, 05:40
Default Multi species solver
  #12
Sorry for late reply (was on Diwali vacation). The problem is solved now. Code is compiling and running. I will update you soon with next development.
Currently, I am trying to introduce heat transfer effects in above developed solver.
Thanks
Hrushikesh
Old   December 1, 2010, 09:05
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Hello Hrushi,
I followed your thread and it seems you've done exactly the same as I am starting to do right now. Is your solver anyway available as a contribution?
If not, what did you change then from the last post on, to make the solver not only compiling but also running?
Best Regards form Zurich to Mumbai,
Tony
alfa_8C is offline   Reply With Quote
Old   December 1, 2010, 23:42
Originally Posted by alfa_8C View Post
Hello Hrushi,
Tony
Hi Tony,
No, it is not. The current solver does only the multi species part without reaction and heat transfer. It just transports mixture of species frpom one point to another. Also, the solver is not stable when it is running. The initial residual values do not come below 0.1. They fluctuate between 0.12 to 0.73. The solution is not converged. Do you know any reason for this?
Also now I am trying to include heat transfer in the above solver by introducing enthalpy equation. I am confused with thermophysical model framework available in OF. Can you help me out in this or give suggestions on it?
Hrushi
Old   December 2, 2010, 05:23
Antonio Liggieri
Hello Hrushi,
what is the reason for you to create a solver with multicomponent mixture model on your own? You could easily use reactingFoam. I think this solver would fulfill all your needs, as it provides mixture, heat transfer, reactions on/off, but no radiation by the way. But this is not really a problem since it is very easy to implement a radiation model in OpenFoam. If you need help regarding this just let me know.
Tony
Old   December 2, 2010, 05:33
Default hi
  #16
the king 2 is on a distinguished road
sry...my reply nt regarding thread..i am new to the forum....iwant to learn gambit and fluent.do u knw some institute for training?
the king 2 is offline   Reply With Quote
Old   December 2, 2010, 06:37
Hello Hrushi,
Tony
Hi Tony,
Thanks for giving your time. The reactingFoam solver updates the species properties using gas law. I don't want that. I needed a solver to solve the reaction, heat transfer in liquid phase with steady state approach and which would update physical properties as mass weighted average. I think reactingFoam doesn't provide this option. If it can, please let me know the way for this. The reason behind developing this solver is that I first wanted to introduce YEqn and calculate mixture density and use this in UEqn followed by heat transfer addition and reaction stuff.
Thanks again for sharing your thought on this. I really appreciate that. Will contact you if I need any help.
Hrushi
Old   December 2, 2010, 06:38
Hello Hrushi,
Tony
Hi Tony,
Thanks for giving your time. The reactingFoam solver updates the physical and thermophysical properties using gas law. I don't want that. I needed a solver to solve the reaction, heat transfer in liquid phase with steady state approach and which would update physical properties as mass weighted average. I think reactingFoam doesn't provide this option. If it can, please let me know the way for this. The reason behind developing this solver is that I first wanted to introduce YEqn and calculate mixture density and use this in UEqn followed by heat transfer addition and reaction stuff.
Hrushi
Old   August 11, 2011, 02:07
Default Multi Species in OpenFOAM
  #19
prasanth
prasanth is on a distinguished road
Hello Hrushi,
I want to solve the multSpecies problem using OpenFOAM. I have seen your posting in forum regarding this solver. Have you success on this solver? If So, Could you please tell me what are the changes did you made for this solver
Regards
Prasanth.
Originally Posted by Hrushi View Post
Hi Cyprien,
Here is my YEqn.H:
mesh,
fields,
phi,
IOobject
"rho_mix",
runTime.timeName(),
mesh,
mesh
mu = (mu1,mu2,mu3);
IOobject
"mu_mix",
runTime.timeName(),
mesh,
mesh
nu = (nu1,nu2,nu3);
solve
fvm::div(phi,Yi)
source_r
Yi.max(0.0);
Yt += Yi;
else
inertIndex = i;
IOobject
"nu_mix",
runTime.timeName(),
mesh,
mu_mix/rho_mix
Thanks and Regards,
Hrushikesh
prasanth is offline   Reply With Quote
Old   January 6, 2015, 03:43
Yu-sen Niu
shenzhou1987 is on a distinguished road
Hello Hrushi,
Tony
Hi Tony
I'm a new one in OpenFOAM. Recently I'm looking for a method to simulate jet flow of a nozzle using OpenFOAM. So the mixture of combustion gas and air must be considered, and I don't want to calculate the reaction of them. I have read the example case of reatingFoam, but I don't know how to set species and turn reaction off. Can U give me some suggestions?
Thank you very much.
shenzhou1987 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Steady state Multi species non-reactive model Hrushi OpenFOAM 4 June 5, 2014 13:00
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Thermal and species transport in steady state mrangitschdowcom OpenFOAM Running, Solving & CFD 3 October 10, 2007 05:21
