BuoyantBoussinesq(Pimple/Piso)Foam, changed equation from OF 1.6 to 1.7 ???
Old   September 27, 2010, 10:37
Default BuoyantBoussinesq(Pimple/Piso)Foam, changed equation from OF 1.6 to 1.7 ???
Jan
myself is on a distinguished road
Hi Folks,
one question regarding the changes from OF 1.6 to 1.7 in the buoyantBoussinesq(Piso/Pimple)Foam solver. I think the implementation of splitting the pressure according to p = p_rgh + rho*g.x is not fully correct.
The pressure equation in OF 1.7 seems OK, since in the Rhie-Chow formulation the contributions from the static pressure cancel and we are left with:
phi = (fvc::interpolate(U) & mesh.Sf())
        + fvc::ddtPhiCorr(rUA, U, phi);
surfaceScalarField buoyancyPhi = rUAf*ghf*fvc::snGrad(rhok)*mesh.magSf();
phi -= buoyancyPhi;
instead of
 surfaceScalarField phiU
    phi = phiU + rUAf*fvc::interpolate(rhok)*(g & mesh.Sf());
in OF 1.6.
In contrast, in the momentum equation the term for the buoyancy ( and gravity) force has changed from (OF 1.6)
fvc::reconstruct( ...
                    fvc::interpolate(rhok)*(g & mesh.Sf())  ...)
to (OF 1.7)
  - ghf*fvc::snGrad(rhok)*mesh.magSf() ...)
These are two different expressions: F ~ rhok * g vs. F ~ gradT * g.h
Is this really a bug or do I miss some point? Thanks for any comment...
Regards,
Jan
Edit:
In the meantime I am pretty sure this is indeed a bug and I submitted a bugreport.
Edit:
Problem is solved. This bug was fixed a few days ago in the git repository.
myself is offline   Reply With Quote
Old   July 28, 2011, 05:21
Anne Gerdes
Anne Lincke is on a distinguished road
Dear Foamers,
can someone explain me why OF1.7 still uses
HTML Code:
instead of
HTML Code:
as it was used in the previous version OF1.6.
I do not understand why the gradient of the densitiy is used while in the equations I find in literature it has to be just the densitiy multiplied with the constant g.
Can someone help me? Is this still a bug or do I overlook something?
Anne Lincke is offline   Reply With Quote
Old   September 13, 2011, 08:38
Anne Gerdes
For the answer see
http://www.cfd-online.com/Forums/ope...implefoam.html
Old   September 14, 2011, 02:03
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Originally Posted by myself View Post
Hi Folks,
phi -= buoyancyPhi;
instead of
in OF 1.6.
to (OF 1.7)
Regards,
Jan
Edit:
Edit:
Hallo Jan!
You wrote that the term in OF17 was formulated with an error, am I correct?
But still if i look OF171 (Ubuntu package installed via apt-get):
            UEqn
            fvc::reconstruct
                  - fvc::snGrad(p_rgh)
                )*mesh.magSf()
Is this term still there? And how it should be?
Regards,
Alexander
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results Arnoldinho OpenFOAM Community Contributions 7 December 9, 2010 16:29
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Compatibility from OF 1.6 to OF 1.7? Chrisi1984 OpenFOAM Installation 2 July 7, 2010 03:07
