How to change the value of an argument of an if-test within the if-scope
Old   September 29, 2010, 04:57
Default How to change the value of an argument of an if-test within the if-scope
Edy
Edy is on a distinguished road
I have a problem which is probably very simple to solve.
In my program, I would like to change, within an if-scope, the value of the variable used in the if-test.
Basically, what i want to do looks like this :
volScalarField Tsub = Tsat - Tb;
if (Tsub <= 0.05)
Tsub = 0.0;
BHowever, OpenFOAM operator<= should normally take references to constant volScalarField as arguments. But then I cannot modify these arguments within the if-scope...
Thanks in advance.
/Edouard
Edy is offline   Reply With Quote
Old   September 29, 2010, 07:04
Stefan Herbert
herbert is on a distinguished road
Hi Edy,
you have to do the change element-wise:
 forAll(Tsub, iCell)
    if (Tsub[iCell] <= 0.05)
        Tsub[iCell] = 0.0;
Regards,
Stefan
herbert is offline   Reply With Quote
Old   September 29, 2010, 08:25
Edy
Hi Stefan,
It works. It was obviously something quite easy but I am still not very familiar with OF, i just started few days ago and have a lot to learn.
Vielen Dank!
Old   September 30, 2010, 07:11
Edy
One more question.
Tsub is defined as a volScalarField with the dimension of temperature. Is it licit to write a test as you wrote though the LHS has a dimension and the RHS is just a scalar: Or should i define a new temperature dimensioned variable equal to 2 for the RHS of the test?
Thanks
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
