Negative reynolds stresses from Spalart Allmaras model
Old   October 15, 2010, 05:49
Default Negative reynolds stresses from Spalart Allmaras model
Alejandro
velezisaza is on a distinguished road
I have an unbearable question about reynolds stresses. I am using simpleFoam to simulate the flow over an airfoil(2D). Since the Spalart Allamaras (SA) model is most appropiate for this I used it. After that I calculated the Reynolds stresses with the utility R. Now my surprise when Rxx and Ryy have negative and positive values. I run the airfoil2D of the tutorials/incompressible/ras, and again there is change of signs in Rxx and Ryy. This means also that the turbulent kinetic energy, defined as the trace of R has positive and negative values!
Can someone explain me this, what am I doing wrong? I have also tried to find the src where R is calculated but have not managed. Can someone point me where to look for this?
Thanks
velezisaza is offline   Reply With Quote
reynolds stress, spalart allmaras, turbulent kinetic energy
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 19:00
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Scaling the Reynolds stresses via UDF Markus FLUENT 1 November 11, 2022 12:44
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Reynolds stress Model Chimenti Martín Main CFD Forum 5 November 21, 2001 13:22
