Modifying rhoSimpleFoam to calculate ptot every iteration
Old   October 13, 2010, 02:59
Default Modifying rhoSimpleFoam to calculate ptot every iteration
RalphS is on a distinguished road
I want to modify rhoSimpleFoam so that it calculate ptot every time. I need ptot to calculate measuring total pressure with simpleFunctionObjects.
So, I have to change createFields.H and my_rhoSimpleFoam.C. I have tried it, but it didn't worked.
In createFields.H, i have add this:
    Info<< "Reading field ptot\n" << endl;
    volVectorField ptot
        IOobject
            "ptot",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        p + 0.5*rho*magSqr(U)
In my_rhoSimpleFoam.C, i have add this:
 ptot = p + 0.5*rho*magSqr(U)
Can someone help me?
RalphS is offline   Reply With Quote
Old   October 13, 2010, 03:09
Sabin Ceuca
sabin.ceuca is on a distinguished road
    volScalarField ptot
        IOobject
            "ptot",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
try it like this. The problem seemed be the declaration of ptot as volVectorField instead of volScalarField.
Ciao,
Sabin
sabin.ceuca is offline   Reply With Quote
Old   October 13, 2010, 03:25
thanks for the fast reply.
I have tried volSalarField, but it doesn't solve the problem.
cpp: Internal error: Floating point exception (program cc1)
Please submit a full bug report.
See <http://gcc.gnu.org/bugs.html> for instructions.
make: *** [linux64GccDPOpt/options] Error 1
make: *** [linux64GccDPOpt/files] Error 1
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
Old   October 13, 2010, 04:20
Stefan Herbert
herbert is on a distinguished road
This doesn't look like a standard compilation error. I think there is something wrong with you compiler itself or with you Make/options (if you changed anything there). Can you try compiling on another maschine?
Regards,
Stefan
herbert is offline   Reply With Quote
Old   October 13, 2010, 05:00
You're right, thanks. I have to use another machine.
Now I can use my_rhoSimpleFoam to calculate ptot.
Here is my code (I have found two faults in it):
my_rhoSimpleFoam.C:
      turbulence->correct();
//BEGIN NEW
 ptot = p + 0.5*rho*magSqr(U);
//END NEW
        runTime.write();
createFields.H
        mesh
//BEGIN  NEW
   Info<< " Reading field ptot\n" << endl;
   volScalarField ptot
      IOobject
        "ptot",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
//END NEW
    #include "compressibleCreatePhi.H"
Regarding Coefficient-of-Discharge of intake port LeelaPrasad Siemens 2 March 9, 2017 05:48
How to calculate the convergence rate of Gauss-Seidel line iteration? hadesmajesty Main CFD Forum 0 November 2, 2009 22:08
RhoSimpleFoam FoamX spv24 OpenFOAM Running, Solving & CFD 1 July 21, 2008 10:29
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
