Buoundary Condition for PisoFoam
Old   October 13, 2010, 15:46
Default Buoundary Condition for PisoFoam
Vishal Jambhekar
vishal is on a distinguished road
Hallow all.
i am using pisofoam for simulation of surfboard fin.
I am using PisoFoam for both steady state and transient state calculation.
B.C inlet and oulet as patchs,
for velocity :
velocity inlet - inlet.
inletoutlet - outlet.
others are zerograd and symmetry plane at bottom.
for pressure :
pressure - outlet.
inlet - zerograd.
value for k and epsilon are calculated for 3m/sec using formula mentioned in userguide.
Still i am getting sudden overshoot in current number after few iterations.
please help me in this regard.
Thanks a ton......
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   October 14, 2010, 02:40
Sabin Ceuca
sabin.ceuca is on a distinguished road
I would start by checking if the mesh is fine enough at „problem zones“and then, if you don’t have good initial values for all your variables, to increase your U,k ,epsilon values in a ramp to the desired what you actually want to simulate.
Greats,
Sabin
sabin.ceuca is offline   Reply With Quote
Old   October 16, 2010, 18:17
Vishal Jambhekar
Yes exactly, I am trying to do the same.
Does changing inlet and Outlet to walls from patch and applying wallfunctions can give better results. as used in cavity case for pisofoam. please let me know.
Thanks
Cheers,
Vishal Jambhekar...
Old   October 18, 2010, 05:32
Sabin Ceuca
Well i don't think it is a good idea to change the inlet & outlet to wall, only if you have something like a tank.
Cheers,
Old   October 21, 2010, 09:17
Vishal Jambhekar
even i thoughe so, But i am really confused.
i am having a case as a wooden block is kept in stream of water.
Outlet : set to zero pressure
inlet : 3 m/sec.
side plaes: are symmetry.
bottom i set to zerograd.
and top also zerograd. i was wondering if i should set different condition at top surf as i have atmosphere there.
what do you think.
Cheers,
Vishal Jambhekar...
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 06:40
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 06:45
