October 15, 2010, 12:15 |
interFoam (OF 1.7.1) in parallel ..need help
Recently I have encountered a problem When I want to run a simple case with interFoam (OF 1.7.1 ) in parallel. the out file shows that After selecting incompressible transport model Newtonian, it crashes ( specially in 3D cases). Actually I dont know it crashes or there is another problem which I cant understand. it is weired because I can run it normally without parallelization without any problem. Sometimes even I can run it in parallel but with few processor( 4 ). Does anybody has this problem with OF 1.7.1? I would be grateful if you guys help me to fix my problem. Thanks, MEhran |
October 15, 2010, 14:45 |
I found out that when I decrease the dimension of my domain in to millimeter. ex.(3mm*1.2mm) independent of the cell size, it crashes when I run it in parallel. ( it runs in order of cm not mm...why???) Why this happen?? can any body help me!!
QUOTE=farhagim;279394]Hello, Recently I have encountered a problem When I want to run a simple case with interFoam (OF 1.7.1 ) in parallel. the out file shows that After selecting incompressible transport model Newtonian, it crashes ( specially in 3D cases). Actually I dont know it crashes or there is another problem which I cant understand. it is weired because I can run it normally without parallelization without any problem. Sometimes even I can run it in parallel but with few processor( 4 ). Does anybody has this problem with OF 1.7.1? I would be grateful if you guys help me to fix my problem. Thanks, MEhran[/QUOTE] |
July 6, 2012, 06:25 |
#3 | |
Hauke
Hey,
I just encountered the same Problem. Sry for digging up this old Thread. Here is my Log: Quote:
Ideas, Anyone? Thank you |
July 25, 2012, 10:37 |
Alessandro Pani
Hi guys, i'm beginning to look at parallelization...
what method did you used in decomposeParDict ? |
July 26, 2012, 16:42 |
Does your case run in serial?
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
InterFoam in parallel | sara | OpenFOAM Running, Solving & CFD | 3 | April 19, 2011 05:05 |
interFoam parallel | bunni | OpenFOAM Bugs | 2 | June 9, 2010 17:39 |
Performance of interFoam running in parallel | hsieh | OpenFOAM Running, Solving & CFD | 8 | September 14, 2006 09:15 |
InterFoam problem running parallel | vatant | OpenFOAM Running, Solving & CFD | 0 | April 28, 2006 19:22 |
