October 20, 2010, 12:49 |
Problem regarding solution under-relaxation
Hi Foamers,
I am modeling subcooled boiling and condensation using a two phase Euler-Euler approach. So i solve mass, momentum and energy conservation equations for both phases. I checked several times my model and i am pretty sure that it is physically correct. I mean, the equations i implemented make sense. However my simulation (a simple 2D channel) crashed very quickly... I think this is due to numerical calculation reasons, so i used relaxation factors, in order to improve the stability of the computation. Here are the solvers and relaxation factors i set: Code:
solvers { p GAMG { tolerance 1e-10; relTol 0; smoother DIC; //GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; Ua PBiCG { preconditioner DILU; tolerance 1e-05; relTol 0.5; }; Ub PBiCG { preconditioner DILU; tolerance 1e-05; relTol 0; }; alpha PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; beta PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; Ha PBiCG { preconditioner DILU; tolerance 1e-5; relTol 0; }; Hb PBiCG { preconditioner DILU; tolerance 1e-5; relTol 0; }; DS PBiCG { preconditioner DILU; tolerance 1e-5; relTol 0; }; Theta PBiCG { preconditioner DILU; tolerance 1e-05; relTol 0; }; k PBiCG { preconditioner DILU; tolerance 1e-05; relTol 0; }; epsilon PBiCG { preconditioner DILU; tolerance 1e-05; relTol 0; }; } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; nAlphaCorr 2; correctAlpha no; pRefCell 0; pRefValue 0.0; } relaxationFactors { alpha 0.3; DS 0.3; p 0.3; Ua 0.3; Ub 0.3; Ha 0.3; Hb 0.3; } Code:
GAMG: Solving for p, Initial residual = 1, Final residual = 5.7155e-11, No Iterations 93 --> FOAM FATAL ERROR: previous iteration field IOobject: volScalarField p "/home/michta/OpenFOAM/michta-1.7.x/run/EulerEulerBoilingFoam/EulerEulerBoilingFoam/referenceCase/0" not stored. Use field.storePrevIter() at start of iteration. From function GeometricField<Type, PatchField, GeoMesh>::prevIter() const in file /home/michta/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/GeometricField.C at line 863. FOAM aborting Thanks in advance! Best, /Edy |
October 20, 2010, 14:18 |
Ben K
Rep Power: 19 |
You may have other problems as well, but in order to use damping factors, you need to store the previous solution. Just place:
FIELD.storePrevIter(); in your solver before solving for the equation. |
October 20, 2010, 14:22 |
Thanks for your answer. But i applied the relaxation on the equation instead of applying it directly on the field, it should work as well, right? Here is my piece of code : Code:
fvScalarMatrix pEqn ( fvm::laplacian(Dp, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); pEqn.relax(); pEqn.solve(); /Edy |
October 20, 2010, 14:24 |
Because for the other fields (velocity, enthalpy, k, epsilon), i also apply the relaxation on the equation, not directly on the field, and I do not have this error message...
October 21, 2010, 09:59 |
Ben K
Rep Power: 19 |
Hmm...you're right...I'm not sure what the problem is. Maybe try underrelaxing the other way to see if that works?
October 21, 2010, 10:15 |
Hi!
Your way works, mine does not, i dont understand why... However even with this underrelaxation, my simulation crashed, so i will check my code, once again.... Thanks for the help! Best /Edy |
March 21, 2013, 13:38 |
#7 | |
Hi All,
I also had a problem about the underrelax factor in openfoam. In my simulation case, I used k-epsilon and rhoSimplecFoam. However, for the relaxation factors of k and epsilon, I need to reduce the factors to very small, less than 0.1. And the iteration step is zero. If I slightly increase the relaxation factors, the simulation will blow up due to large k or epsilon. Does anybody know what is the underlying reason behind this problem? Quote:
August 8, 2013, 04:01 |
Anne Gerdes
You have to insert
HTML Code:
p.storePrevIter(); So try to insert it before HTML Code:
#include "pEqn.H" |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 13:44 |
Fluent VOF Volume of Fluid Realistic Solution Problem | wormik | FLUENT | 3 | June 21, 2009 08:04 |
Discretization problem in Solution controls | Tamm | FLUENT | 0 | July 15, 2005 08:07 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 09:40 |
Symmetric problem - Asymmetric prediction | Mark | Main CFD Forum | 14 | January 29, 2001 14:21 |
