Apply deltaT in utility
Like Tree1Likes
  • 1 Post By MartinB
Old   December 10, 2010, 11:39
Default Apply deltaT in utility
Bo Terp Paulsen
botp is on a distinguished road
Dear all,
At the moment I am trying to modify a utility file, where I want to multiply a constant by deltaT. I use a fixed Courant number, so I do not know the time step beforehand.
I have tried the following:
alpha=C*runTime.deltaT().value();
where alpha is the expression I want to modify, and C is a constant.
When I recompile the utility I get the following error message: error: ‘runTime’ was not declared in this scope.
I know there is not much information in the post, but if anybody could give me an advise on how to declare runTime, it will be appreciated.
Kind regards,
Bo Terp
Ps. I am using OF 1.5-dev
botp is offline   Reply With Quote
Old   December 10, 2010, 13:37
Martin
MartinB will become famous soon enough
Hi Bo Terp,
have a look at /applications/utilities/postProcessing/wall/wallGradU/wallGradU.C for example.
Here is a code snippet that shows how to access the time values:
    ... header from wallGradU.C ...
int main(int argc, char *argv[])
    timeSelector::addOptions();
    #include "setRootCase.H"
#   include "createTime.H"
    instantList timeDirs = timeSelector::select0(runTime, args);
#   include "createMesh.H"
    scalar lastTimeStep = 0; // added
    scalar deltaTime = 0; // added
    forAll(timeDirs, timeI)
        runTime.setTime(timeDirs[timeI], timeI);
        deltaTime = timeDirs[timeI].value() - lastTimeStep; // added
        lastTimeStep = timeDirs[timeI].value(); // added
        Info<< "Time = " << runTime.timeName() << endl;
        Info<< "deltaT = " << deltaTime << endl; // added
        ... more code ...
Martin
hojjat.m likes this.
MartinB is online now   Reply With Quote
deltat, openfoam 1.5-dev
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 18:04
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 02:00
How to compile a new utility rudy OpenFOAM 4 October 1, 2011 22:48
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 0 February 5, 2010 12:12
Courant utility does not always use correct deltat schmidt_d OpenFOAM Bugs 0 June 5, 2007 11:45
