mutRoughWallFunction
Old   September 1, 2010, 06:38
Default mutRoughWallFunction
OMN
Olivier Macchion
OMN is on a distinguished road
Hello
I tried to set up a rough wall for a run with buoyantSimpleFoam using the syntax:
wall
type mutRoughWallFunction;
Ks uniform 0.005;
Cs uniform 0.5;
value uniform 0;
and I got this error message after starting buoyantSimpleFoam:
Selecting RAS turbulence model realizableKE
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 log in "/lib/tls/i686/cmov/libm.so.6"
#4 Foam::compressible::RASModel::yPlusLam(double, double) const in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#5 Foam::compressible::RASModels::mutRoughWallFunctio nFvPatchScalarField::calcMut() const in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#6 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#7 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/buoyantSimpleFoam"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/opt/openfoam170/applications/bin/linuxGccDPOpt/buoyantSimpleFoam"
#9 Foam::compressible::RASModels::realizableKE::reali zableKE(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#10 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::realiza bleKE>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#12
#13 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#14
Floating point exception
Would someone know what the problem is? Everything works fine with mutWallFunction.
I also tried to use mutRoughWallFunction in the hotroom tutorial for buoyantSimpleFoam but I got the same error message. Is this a bug or my lack of understanding of the use of mutRoughWallFunction?
Cheers
Olivier
OMN is offline   Reply With Quote
Old   November 10, 2010, 13:09
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
Please try this
export FOAM_SIGFPE=false
unset FOAM_SIGFPE
aerothermal is offline   Reply With Quote
buoyant flows, buoyantsimplefoam, mutroughwallfunction, wall functions
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
