Very basic problem with surfaceScalarField definition
Old   December 7, 2011, 04:31
Default Very basic problem with surfaceScalarField definition
Yuri Feldman
feldy77 is on a distinguished road
Dear Foamers,
I am realy stuck with very simple problem. I am intersted in definition new
surfaceScalarField which will correspond to to the flux of new variable phitag.
I want to do it within my own function by this way:
#include "surfaceInterpolationScheme.H"
#include "linear.H"
#include "fvCFD.H"
void MV(volVectorField*FunU,volScalarField*FunV, volVectorField*ResU, volVectorField*ResV, const fvMesh&mesh )
surfaceScalarField phitag
IOobject
"phitag",
mesh.time(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
linearInterpolate(FunU) & mesh.Sf()
The compilation results in error related with mesh.time() and with linearInterpolate .
Namely :
no matching function for call to 'linearInterpolate(Foam::volVectorField*&)'
Any suggestions please,
Yuri
feldy77 is offline   Reply With Quote
Old   December 7, 2011, 09:09
Steven van Haren
stevenvanharen is on a distinguished road
Maybe try:
linearInterpolate(&FunU) & mesh.Sf()
It looks like there is some problem with the fact that you pass a pointer to the function?
How are you going to use this piece of code?
stevenvanharen is offline   Reply With Quote
Old   December 7, 2011, 09:16
Disabled
anon_a is on a distinguished road
Have you tried this?
fvc::interpolate(FunU) & mesh.Sf()
You can find something similar for phi in some solvers.
EDIT: Sorry, didn't see the pointer.
anon_a is offline   Reply With Quote
Old   December 7, 2011, 20:11
Yuri Feldman
Thank you for you help,
the code is compiled by changing to
linearInterpolate(*FunU) & mesh.Sf()
Now the problem is what to do with
mesh.time()
If remove the line the code is passing compilation but it is not clear for me what the constructor takes by deffault.
Does anybody know where I can look at comprehensive description of IOobject constructor to understand how it works.
Old   December 8, 2011, 13:13
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Look at the OF source docs online (http://www.openfoam.com/docs/cpp/), and search for IOobject. This will give you everything you want to know about this class (as well as any others you care to search for).
mturcios777 is offline   Reply With Quote
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt vlnikolic Main CFD Forum 3 September 16, 2016 04:07
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Basic Comsol CAD Problem Sapo COMSOL 0 August 27, 2010 14:58
Multiphase region definition problem Shahed CFX 6 August 16, 2010 03:33
Specious transport (mixture definition problem) MASOUD FLUENT 0 June 7, 2010 23:34
