interFoam - mass conservation
Like Tree4Likes
  • 4 Post By carsten
Old   August 5, 2009, 16:00
Exclamation interFoam - mass conservation
Wolfgang Betz
wbetz is on a distinguished road
Why isn't the boundary condidition 'zeroGradient' for pressure on walls not working anymore in OpenFOAM 1.6 (interFoam)? (if you do, there is a problem with mass conservation ...)
walls
type zeroGradient;
... instead you have to use: (why ???)
walls
type buoyantPressure;
value uniform 0;
cheers
Wolfgang
wbetz is offline   Reply With Quote
Old   August 6, 2009, 01:40
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I suppose this is due to the replacement of pd with static pressure p.
Have a look into the Release Notes for version 1.6 (Section 5.1 Solver restructuring):
pd replaced by static pressure p. All solvers in which buoyancy affects might be strong have been converted from using pd to p with improved numerics to give equally good accuracy and stability. This change is prompted by the need to remove the confusion surrounding the meaning and purpose of pd.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 6, 2009, 03:51
Wolfgang Betz
I agree with that - however, does somebody has more information on that behaviour ('zeroGradient' for pressure on walls ist not working anymore)?
And are there any other BCs you have to be aware of (as to a similar behaviour) in OF-version 1.6?
Old   September 21, 2009, 10:40
Carsten Thorenz
carsten is on a distinguished road
Dear Wolfgang,
due to the nature of the PISO-algorithm used in interFoam, it is necessary to have a very "good" pressure field, as the pressure field is required in the velocity correction step of the scheme in order to reach mass conservation (i.e.div(U)=0).
If you look at the PISO-algorithm you will see that this means if the flux is zero (as it is orthogonal to the wall) it is necessary that the second derivative of pressure (orthogonal to the wall) must be zero, too (in areas where the density is constant).
buoyantPressure fulfills this requirement in areas of constant VOF-function / density. I'm not sure about mass conservation if sloped walls touch areas with VOF-values 0<VOF<1.
Bye and good luck,
Carsten Thorenz
maddalena, mgg, Pirlu and 1 others like this.
carsten is offline   Reply With Quote
Old   December 7, 2010, 15:22
Claus Meister
idrama is on a distinguished road
Has anybody ever done a mass conservation analysis in a pipe flow within VOF approach?
idrama is offline   Reply With Quote
buoyantpressure, interfoam, walls, zerogradient
InterFoam mass conservation question msrinath80 OpenFOAM Running, Solving & CFD 5 December 9, 2013 01:19
Mass Conservation in LES Sas Main CFD Forum 3 July 6, 2007 10:37
Mass Conservation in LES Jaswant Main CFD Forum 8 July 4, 2005 22:32
Mass conservation Diego Nogueira Main CFD Forum 1 July 30, 2004 15:50
Two-phase mass conservation ? Michael R. Rasmussen CFX 3 September 1, 2000 08:36
