July 12, 2010, 02:57 |
What is the Avearage in dynSmargrinsky model
Dear everyone:
So far as I know, in dynamic smargrinsky model, the original way to calculated cD is unstable , so ensemble average is introduced to resovle the problem such as negetive value of cD. so you can find in http://foam.sourceforge.net/doc/Doxy...agorinsky.html : cD=<L.M>/<M.M>, which is intead of cD=L.M/M.M, where < > means ensemble average. But I don`t know what is the " average " in the source code ? it seems like that it is the "Arithmetic average:" for the field if that the cD is not the funtion of space.as original idea for dynamic model is to make the cD to be the function of time and space--cD=cD(x,t) so if anyone can tell me where is the code of the original function type for the average here in the code Thanks 00052 00053 dimensionedScalar dynSmagorinsky::cD(const volSymmTensorField& D) const 00054 { 00055 volSymmTensorField LL = dev(filter_(sqr(U())) - (sqr(filter_(U())))); 00056 00057 volSymmTensorField MM = 00058 sqr(delta())*(filter_(mag(D)*(D)) - 4*mag(filter_(D))*filter_(D)); 00059 00060 dimensionedScalar MMMM = average(magSqr(MM)); 00061 00062 if (MMMM.value() > VSMALL) 00063 { 00064 return average(LL && MM)/MMMM; 00065 } 00066 else 00067 { 00068 return 0.0; 00069 } 00070 } 00071 |
January 24, 2011, 08:54 |
average(volScalarField) -> implementation?
Bernhard Grieser
Rep Power: 16 |
I'd like to know that as well.
How's average(volScalarField) implemented? |
January 24, 2011, 21:48 |
Hope this helps!
Charlie
Rep Power: 15 |
See the source file about average(): http://foam.sourceforge.net/doc/Doxy...8C_source.html you can see some useful field functions( including average(),pow() etc) there |
January 25, 2011, 03:24 |
#4 | |
Bernhard Grieser
Rep Power: 16 |
Regards, Bernhard |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
