runtime cuttingplanes in simpleFoam
Old   March 15, 2010, 08:26
Default runtime cuttingplanes in simpleFoam
Luc Bordier
lbordier is on a distinguished road
I'm trying to use sampling with cuttingplanes during run time.
For this, I modified the simpleFoam.C file by including some code taken from sample utility in the main while loop :
IOsampledSurfaces sSurfs
        sampledSurfaces::typeName,
        mesh,
        "sampleDict",
        IOobject::MUST_READ,
        true
        // Handle geometry/topology changes
        //polyMesh::readUpdateState state = mesh.readUpdate();
        //sSurfs.readUpdate(state);
        sSurfs.write();
        Info<< "write cuttingplanes at Time = " << runTime.timeName() << nl << endl;
All this works well, fields on cutting planes are written for each time step with the information given in sampleDict.
But now, I would like to use the fields on cuttingplane to compute statistics (mean of field, standard deviation on the cutting plane,...).
Can somenone help me to replace the sSurfs.write() statement with some code that could allow me to retrieve the fields value and to operate on them ?
Thanks
lbordier is offline   Reply With Quote
Old   December 14, 2010, 08:31
fisch
fisch is on a distinguished road
i tried to do similar things.
I want to sample some fields (e.g. velocity) during runtime within a dynamic Mesh solver (in my special case piso).
My problem is that i'm getting a memory error as soon as i want to perform meshMotion.
Do you have an idea how to handle it?
thanks
fisch is offline   Reply With Quote
cutting, plane, sample, sampling, simplefoam
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
SimpleFoam result for turbFoam initialisation philippose OpenFOAM Running, Solving & CFD 0 November 26, 2006 10:24
