compressible flow solver in OF1.6
Old   April 28, 2010, 09:33
Question compressible flow solver in OF1.6
KGN
mecbe2002 is on a distinguished road
Hi all,
Why PISO & SIMPLE algorithms are used in OF for compressible flow problems. These algorithms are for pressure linked equation i.e. incompressible flows and for low Mach no flows.
Even density based solver "rhoSonicFoam" uses PISO algorithm why?
In compressible flows computation, we solve momentum equation to get velocity, energy equation to get temperature, density from continuity equation and pressure from perfect gas equation. correct me if i am wrong.
If this is the case, then why PISO & SIMPLE come into picture.
Thanks
mecbe
mecbe2002 is offline   Reply With Quote
Old   April 29, 2010, 11:04
Ngoc-Minh Truong
truong_nm is on a distinguished road
Send a message via MSN to truong_nm
You'll find some answers here:
http://www.cfd-online.com/Forums/ope...mple-piso.html
Enjoy
truong_nm is offline   Reply With Quote
Old   April 29, 2010, 12:52
KGN
I read the thread and it was mentioned that steady state problem has to be solved by Pseudo Transient for stability. Can you give some details on it, because i am in the process of converting the "rhoSonicFoam" inviscid density based transient compressible flow solver(this doesn't uses PISO algorithm).
thanks
mecbe
Old   April 30, 2010, 01:07
Alberto Passalacqua
Please, define the problem you want to solve, or we cannot give any specific answer. What is the Mach number, for example?
In addition, what do you mean with "converting" rhoSonicFoam? It is already a transient solver, and it doesn't use the PISO algorithm because it is density based.
Best,
Alberto Passalacqua
Old   April 30, 2010, 01:17
KGN
Hi Alberto,
I want to solve transonic & supersonic inviscid steady flow over missile.
Mach No -0.9,1.2,1.8 & 2.5.
I saw the "rhoSonicFoam" code, it doesnt uses PISO algorithm, but in tutorial case file, it was there. sorry for that.
I want to convert it to steady state solver, bcz transient solver takes lot of time to converge.
One more question, can you explain about the slip boundary condition (other than given in the user guide).
Also, i want to implement some more inviscid flux discretization schemes like AUSM, HLLC.. Can you give some advice on how to carry on.
Thanks
mecbe
Old   April 30, 2010, 01:40
Alberto Passalacqua
Originally Posted by mecbe2002 View Post
Hi Alberto,
You might want to take a look also to rhoCentralFoam and rhopSonicFoam.
What is not clear?
Best,
Alberto Passalacqua
Old   April 30, 2010, 02:37
KGN
I will look into those two schemes.
What about implementing new inviscid flux computation schemes like AUSM, HLLC.
thanks
mecbe
Old   April 30, 2010, 12:06
Alberto Passalacqua
thanks
mecbe
There's quite some work to do to be able to implement those. You might want to take a look at aeroFoam:
http://www.cfd-online.com/Forums/ope...-aerofoam.html
Best,
Alberto Passalacqua
Old   April 30, 2010, 12:50
KGN
Hi Alberto,
Thanks for the thread. I downloaded the solver.
This will help a lot for my work.
thanks
mecbe
Old   December 25, 2010, 09:17
rock.senthilkumar's Avatar
senthilkumar.R
rock.senthilkumar is on a distinguished road
Hi mecbe,
Please reply with AeroFOAM (its written for OF V 1.4.1) compatibility problem in OF V 1.6 + .
rock.senthilkumar is offline   Reply With Quote
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 11:33
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
About compressible flow at low mach hit Main CFD Forum 2 October 26, 2009 21:21
Incompressible and compressible flow boris FLUENT 0 February 20, 2002 03:08
