How to run airFoil2D exapmle in parallel on 4 cores?
Old   January 8, 2011, 15:58
Default How to run airFoil2D exapmle in parallel on 4 cores?
Klaus
klausb will become famous soon enough
I tried to run the airFoil2D example in parallel (4 core processor) using mpi but it didn't work. What's wrong?
My approach:
1. Created a decomposeParDict (and set y to 0 since it's a 2D case)
2. Ran decomposePar
3. Changed the Allrun batch file
decomposeParDict:
numberOfSubdomains 4;
method simple;
simpleCoeffs
n ( 2 2 0 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 0 );
delta 0.001;
order xyz;
metisCoeffs
processorWeights ( 1 1 1 1 );
manualCoeffs
dataFile "";
distributed no;
roots ( );
Allrun:
#!/bin/sh
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
application=`getApplication`
#runApplication $application
mpirun -np 4 $application -parallel > log &
klausb is offline   Reply With Quote
Old   January 8, 2011, 21:15
Smile Run Parallel
Charlie
cheng1988sjtu is on a distinguished road
Since it's 2D case, and it's in xz plane, so maybe in the following line you can try:
simpleCoeffs
n ( 2 1 2 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 1 );
delta 0.001;
order xyz;
Hope it works~
cheng1988sjtu is offline   Reply With Quote
Old   January 9, 2011, 02:45
Default Solution
Klaus
Thank you! Also, the header text must be there.
Solution:
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object decomposeParDict;
method simple;
simpleCoeffs
n ( 2 1 2 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 1 );
delta 0.001;
order xyz;
metisCoeffs
manualCoeffs
dataFile "";
distributed no;
roots ( );
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
Swap usage on parallel run nikhilesh OpenFOAM Running, Solving & CFD 0 April 30, 2009 09:50
Parallel Run Problems Jason Siemens 1 November 24, 2008 12:32
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 09:54
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 08:53
