Different inlet U values steady state
Old   January 17, 2011, 18:53
Question Different inlet U values steady state
Alexandre Rubel
alex_rubel is on a distinguished road
Hi everyone, I'm a new user of OpenFOAM and I have to make a lot of simulation to validate the use of OF for my case instead of software like Fluent or CFX.
I'm using simpleFoam and I'm looking for an way to make a yaw study.
I want to create a file with all the u_x u_y u_z values for yaws from 0 to 20 deg and to ask Of to take these values for the inlet automatically. For example every 2000 timestep, 0deg for 2000 timestep and restart automatically with the 2deg value for an other 2000 timestep ...
My other idea is to use "timeVaryingUniformFixedValue" for U :
boundaryField
SURFACE_INLET
type timeVaryingUniformFixedValue
fileName "FOAM_CASE/U_inlet.timeprof";
outOfBounds clamp;
and to create a file U_inlet.timeprof with
(0 (3.2294 0 0)) 10 (timestep(u_x u_y u_z))
(2000(x y z))
but i don't know of to set a cos/sin dependance for x y and z
I hop I'm clear of what I want and you can help me
Thanks
Alex
alex_rubel is offline   Reply With Quote
Old   January 18, 2011, 10:37
Alton Luder III
sleepdeprivation is on a distinguished road
Have you thought about setting up a script to run the different cases?
check out pyFoam http://openfoamwiki.net/index.php/Contrib_PyFoam
especially pyFoamClearCase.py and pyFoamWriteDictionary.py
sleepdeprivation is offline   Reply With Quote
Old   January 18, 2011, 15:16
Default what about a bash script?
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Although PyFoam is really great, I found it frustrating to learn OpenFoam and PyFoam at the same time. How about just taking an Allrun script (from many of the tutorials) and setting up your cases that are eventually run by your script? A script could look like:
#!/bin/bash
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
#move into the first case
cd case1
printf "starting simplFoam"
#print start time
date
#decompose the mesh assuming you have decomposeParDict correct
    runApplication decomposePar
#parallel run with 8 processes
    runParallel simpleFoam 8 system/machines
#reconstruct the domain
    runApplication reconstructPar
#print the end time and date
date
#now move to the second case
cd ../case2
#repeat first set of commands
this of course could be run above the first case and as long as everything has been initialized then it will run well. I suggest getting one working well with all your specifics correct (solver settings, descritization, convergence criteria, initial conditions, etc. ) and then running them in sequence. I really like PyFoam, but it can be tough to get started using without much experience in OF. Good Luck.
Dan
chegdan is offline   Reply With Quote
Old   January 18, 2011, 17:30
Alexandre Rubel
Thanks for your answers, I looked at pyFoam but it's seems hard to get something working in one or two days and i need to set that asap.
Thanks a lot Dan it seems a very good idea, I'm going to try today, I started a Java program with eclipse but get some problems.
I'll try to set the Allrun file.
Thanks again
Alex
Old   January 18, 2011, 17:59
Alexandre Rubel
I add some thing in your code Dan tell me if it's good. I usually use the following command to run parallel case :
mpirun -np 6 simpleFoam -parallel > log &
I want to know if "runParallel simpleFoam 6 system/machine" will do he same thing
#!/bin/bash
cd 4deg
#print start time
date
#copy 0 to 0.org
    cp -r 0 0.org
#run potentialFoam
    runApplication potentialFoam -writep
    runParallel simpleFoam 6 system/machines
    runApplication reconstructPar -latestTime
date
cd ../6deg
Old   January 18, 2011, 18:14
Daniel P. Combest
yeah the mpirun command is in the runParallel simpleFoam 6 system/machines command. The machines file in the system folder must be there and that contains the hostname of the computer (it doesn't need the number of processors for this command).
Old   January 18, 2011, 18:22
Alexandre Rubel
I don't have a machine file in my system folder. Can you give a copy of this file ?
Thanks
Old   January 18, 2011, 18:33
Daniel P. Combest
go to the terminal and type
hostname > machines
then put that file in your system folders
Old   January 18, 2011, 18:43
Alexandre Rubel
Ok thanks a lot for everything. Hope it will be ok
Old   January 19, 2011, 18:12
Alexandre Rubel
Hi, I try to launch it this morning and I got this error message :
.: 3: Can't open /bin/tools/RunFunctions
Old   January 19, 2011, 18:40
Daniel P. Combest
Make sure all of your openfoam variables are sourced properly, in this case its $WM_PROJECT_DIR
if you type
echo $WM_PROJECT_DIR
then something like
/home/dcombest/OpenFOAM/OpenFOAM-1.6-ext
should come up. if not then something is wrong with your install.
Dan
Old   January 19, 2011, 18:58
Alexandre Rubel
I got :
/home/arubel/OpenFOAM/OpenFOAM-1.6
Old   January 19, 2011, 19:30
Daniel P. Combest
does /home/arubel/OpenFOAM/OpenFOAM-1.6/bin/tools/RunFuntions exist?
are you calling the script correctly?
If you call it from the directory where is exists then call it by
./ScriptName
or
sh ScriptName.sh
are you using the bash shell?
echo $SHELL should give you /bin/bash
It should work if all is set up correctly. Paste the whole script if you want me to try.
Old   January 19, 2011, 19:37
Alexandre Rubel
I'm using ubuntu so it's a bash shell. And The RunFunctions files exist in the /home/arubel/OpenFOAM/OpenFOAM-1.6/bin/tools/
I don't really understans what i have to do with
 ./ScriptName
here is my Allrun file :
#!/bin/sh
cd 4deg
#print start time
date
#copy 0 to 0.org
cp -r 0 0.org
#run potentialFoam
date
cd ../6deg
#print start time
date
#copy 0 to 0.org
cp -r 0 0.org
#run potentialFoam
date
and the RunFunction file :
#---------------------------------*- sh -*-------------------------------------
# \\ / F ield | OpenFOAM: The Open Source CFD Toolbox
# \\ / O peration |
# \\ / A nd | Copyright (C) 1991-2009 OpenCFD Ltd.
# \\/ M anipulation |
# License
# This file is part of OpenFOAM.
# OpenFOAM is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by the
# Free Software Foundation; either version 2 of the License, or (at your
# option) any later version.
# OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
# for more details.
# You should have received a copy of the GNU General Public License
# along with OpenFOAM; if not, write to the Free Software Foundation,
# Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
# Script
# RunFunctions
# Description
getApplication ()
grep application system/controlDict | sed "s/application *\([a-zA-Z]*\);/\1/"
runApplication ()
APP_RUN=$1; shift
APP_NAME=${APP_RUN##*/}
if [ -f log.$APP_NAME ] ; then
echo "$APP_NAME already run on $PWD: remove log file to run"
else
echo "Running $APP_RUN on $PWD"
$APP_RUN $* > log.$APP_NAME 2>&1
fi
runParallel ()
APP_RUN=$1; shift
if [ -f $log.$APP_RUN ] ; then
echo "$APP_RUN already run on $PWD: remove log file to run"
else
echo "Running $APP_RUN in parallel on $PWD using $1 processes"
( mpirun -np $1 $APP_RUN -parallel < /dev/null > log.$APP_RUN 2>&1 )
fi
compileApplication ()
echo "Compiling $1 application"
wmake $1
cloneCase ()
if [ -d $2 ] ; then
echo "Case already cloned: remove case directory $2 to clone"
else
echo "Cloning $2 case from $1"
mkdir $2
cpfiles="0 system constant"
for f in $cpfiles
do
cp -r $1/$f $2
done
fi
Old   January 19, 2011, 19:56
Daniel P. Combest
sorry...the ./ScriptName is actually ./Allrun I just wasnt sure what you called your script. I will try this tomorrow morning....Im out of the office.
Old   January 19, 2011, 21:50
Daniel P. Combest
I tried your script and it worked where it was suppose to work. I'm not sure what the issue is on your system.
Old   January 19, 2011, 22:01
Alexandre Rubel
Could it be a problem of authorisation because I always have to use sudo to source something ...
Old   January 19, 2011, 22:27
Daniel P. Combest
That might be the problem. My install is in my home directory.
automatically, change, inlet, simplefoam, speed
Arithmetic mean of velocity (steady - state) lentschi CFX 3 January 11, 2011 06:18
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
Steady state formulation of turbulence ?? Jitendra Main CFD Forum 1 June 27, 2000 18:49
