March 11, 2012, 12:40 |
BlockMesh CheckMesh error Help!!!
deepaktbabu
Rep Power: 14 |
Hi there,
I am trying to blockmesh a cylinder in crossflow in order to predict the nature of flow over cylinder at high Reynolds numbers. I am getting errors while doing checkmesh but my blockmesh is working and i could not really figure of what the error is. my blockmesh Dict is attached here and the error showing is the following.. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : checkMesh Date : Mar 11 2012 Time : 17:35:15 Host : javlin-laptop PID : 2489 Case : /home/javlin/Desktop/blockcyl nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 488 internal points: 0 faces: 868 internal faces: 380 cells: 208 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 208 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology inlet 12 26 ok (non-closed singly connected) outlet 12 26 ok (non-closed singly connected) cylslip 32 68 ok (non-closed singly connected) cyl 16 32 ok (non-closed singly connected) frontnback 416 488 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-2.1 -2.1 0) (6 2.1 0.01) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. ***Boundary openness (-5.88569455308e-20 0.00237684432174 -8.03050527735e-16) possible hole in boundary description. ***Open cells found, max cell openness: 1, number of open cells 16 <<Writing 16 non closed cells to set nonClosedCells Minumum face area = 0.000585271430948. Maximum face area = 0.51707175. Face area magnitudes OK. Min volume = 2e-300. Max volume = 0.00253339125. Total volume = 0.0749627349825. Cell volumes OK. Mesh non-orthogonality Max: 180 average: 115.23387393 ***Number of non-orthogonality errors: 272. <<Writing 272 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 880 faces are incorrectly oriented. <<Writing 608 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.509591935268 OK. Failed 4 mesh checks. End Please help!! my blockmeshdict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-150 0 0) (-106.066 106.066 0) (0 150 0) (106.066 106.066 0) (150 0 0) (106.066 -106.066 0) (0 -150 0) (-106.066 -106.066 0) (-1500 0 0) (-1060.660 1060.660 0) (0 1500 0 ) (1060.660 1060.660 0) (1500 0 0) (1060.660 -1060.660 0) (0 -1500 0) (-1060.660 -1060.660 0) (-2100 -2100 0) (-2100 -1060.660 0) (-2100 0 0) (-2100 1060.660 0) (-2100 2100 0) (-1060.660 -2100 0) (-1060.660 2100 0) (0 -2100 0) (0 2100 0) (1060.660 -2100 0) (1060.660 2100 0) (2100 -2100 0) (2100 -1060.660 0) (2100 0 0) (2100 1060.660 0) (2100 2100 0) (6000 -2100 0) (6000 -1060.660 0) (6000 0 0) (6000 1060.660 0) (6000 2100 0) (-150 0 10) (-106.066 106.066 10) (0 150 10) (106.066 106.066 10) (150 0 10) (106.066 -106.066 10) (0 -150 10) (-106.066 -106.066 10) (-1500 0 10) (-1060.660 1060.660 10) (0 1500 10) (1060.660 1060.660 10) (1500 0 10) (1060.660 -1060.660 10) (0 -1500 10) (-1060.660 -1060.660 10) (-2100 -2100 10) (-2100 -1060.660 10) (-2100 0 10) (-2100 1060.660 10) (-2100 2100 10) (-1060.660 -2100 10) (-1060.660 2100 10) (0 -2100 10) (0 2100 10) (1060.660 -2100 10) (1060.660 2100 10) (2100 -2100 10) (2100 -1060.660 10) (2100 0 10) (2100 1060.660 10) (2100 2100 10) (6000 -2100 10) (6000 -1060.660 10) (6000 0 10) (6000 1060.660 10) (6000 2100 10) ); blocks ( hex (8 0 37 45 9 1 38 46) (2 1 2) simpleGrading (1 1 1)//cyl hex (18 8 45 55 19 9 46 56) (4 1 2) simpleGrading (1 1 1)// inlet u hex (1 2 39 38 9 10 47 46) (2 1 2) simpleGrading (1 1 1)//cyl hex (2 3 40 39 10 11 48 47) (2 1 2) simpleGrading (1 1 1)//cyl hex (4 12 49 41 3 11 48 40) (2 1 2) simpleGrading (1 1 1)//cyl hex (12 29 66 49 11 30 67 48) (4 1 2) simpleGrading (1 1 1)//outlet u 1 hex (29 34 71 66 30 35 72 67) (4 1 2) simpleGrading (1 1 1)//outlet u 2 hex (17 15 52 54 18 8 45 55) (4 1 2) simpleGrading (1 1 1)// inlet d hex (15 7 44 52 8 0 37 45) (2 1 2) simpleGrading (1 1 1)//cyl hex (15 14 51 52 7 6 43 44) (2 1 2) simpleGrading (1 1 1)//cyl hex (14 13 50 51 6 5 42 43) (2 1 2) simpleGrading (1 1 1)//cyl hex (5 13 50 42 4 12 49 41) (2 1 2) simpleGrading (1 1 1)//cyl hex (13 28 65 50 12 29 66 49) (4 1 2) simpleGrading (1 1 1)// outlet d 1 hex (28 33 70 65 29 34 71 66) (4 1 2) simpleGrading (1 1 1) // outlet d 2 hex (16 21 58 53 17 15 52 54) (4 1 4) simpleGrading (1 1 1)// <1> hex (21 23 60 58 15 14 51 52) (2 1 4) simpleGrading (1 1 1)// A hex (23 25 62 60 14 13 50 51) (2 1 4) simpleGrading (1 1 1)// B hex (25 27 64 62 13 28 65 50) (4 1 4) simpleGrading (1 1 1)// <2> hex (27 32 69 64 28 33 70 65) (4 1 4) simpleGrading (1 1 1)// <3> hex (20 22 59 57 19 9 46 56) (4 1 4) simpleGrading (1 1 1)// <4> hex (22 24 61 59 9 10 47 46) (2 1 4) simpleGrading (1 1 1)// C hex (24 26 63 61 10 11 48 47) (2 1 4) simpleGrading (1 1 1) // D hex (26 31 68 63 11 30 67 48) (4 1 4) simpleGrading (1 1 1)// <5> hex (31 36 73 68 30 35 72 67) (4 1 4) simpleGrading (1 1 1)// <6> ); edges ( arc 8 9 (-1385.819 574.025 0) arc 9 10 (-574.025 1385.819 0) arc 10 11 (574.025 1385.819 0) arc 11 12 (1385.819 574.025 0) arc 12 13 (1385.819 -574.025 0) arc 13 14 (574.025 -1385.819 0) arc 14 15 (-574.025 -1385.819 0) arc 15 8 (-1385.819 -574.025 0) arc 0 1 (-138.582 57.403 0) arc 1 2 (-57.403 138.582 0) arc 2 3 (57.403 138.582 0) arc 3 4 (138.582 57.403 0) arc 4 5 (138.582 -57.403 0) arc 5 6 (57.403 -138.582 0) arc 6 7 (-57.403 -138.582 0) arc 7 0 (-138.582 -57.403 0) arc 45 46 (-1385.819 574.025 10) arc 46 47 (-574.025 1385.819 10) arc 47 48 (574.025 1385.819 10) arc 48 49 (1385.819 574.025 10) arc 49 50 (1385.819 -574.025 10) arc 50 51 (574.025 -1385.819 10) arc 51 52 (-574.025 -1385.819 10) arc 52 45 (-1385.819 -574.025 10) arc 37 38 (-138.582 57.403 10) arc 38 39 (-57.403 138.582 10) arc 39 40 (57.403 138.582 10) arc 40 41 (138.582 57.403 10) arc 41 42 (138.582 -57.403 10) arc 42 43 (57.403 -138.582 10) arc 43 44 (-57.403 -138.582 10) arc 44 37 (-138.582 -57.403 10) ); boundary ( inlet { type patch; faces ( (18 19 56 55) (19 20 57 56) (17 18 55 54) (16 17 54 53) ); } outlet { type patch; faces ( (36 35 72 73) (35 34 71 72) (34 33 70 71) (33 32 69 70) ); } cylslip { type slip; faces ( (20 22 59 57) (22 24 61 59) (24 26 63 61) (26 31 68 63) (31 36 73 68) (21 16 53 58) (23 21 58 60) (25 23 60 62) (27 25 62 64) (32 27 64 69) ); } cyl { type wall; faces ( (0 1 38 37) (1 2 39 38) (2 3 40 39) (3 4 41 40) (4 5 42 41) (5 6 43 42) (6 7 44 43) (7 0 37 44) ); } frontnback { type empty; faces ( (16 21 15 17) (21 23 14 15) (23 25 13 14) (25 27 28 13) (27 32 33 28) (17 15 8 18) (15 7 0 8) (15 14 6 7) (14 13 5 6) (13 12 4 5) (13 28 29 12) (28 33 34 29) (18 8 9 19) (8 0 1 9) (1 2 10 9) (2 3 11 10) (4 12 11 3) (12 29 30 11) (29 34 35 30) (19 9 22 20) (9 10 24 22) (10 11 26 24) (11 30 31 26) (30 35 36 31) (53 54 52 58) (58 52 51 60) (60 51 50 62) (62 50 65 64) (64 65 70 69) (54 55 45 52) (52 45 37 44) (52 44 43 51) (51 43 42 50) (50 42 41 49) (50 49 66 65) (65 66 71 70) (55 56 46 45) (45 46 38 37) (46 47 39 38) (47 48 40 39) (40 48 49 41) (48 67 66 49) (67 72 71 66) (56 57 59 46) (46 59 61 47) (47 61 63 48) (48 63 68 67) (67 68 73 72) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Face orientation in blockMesh | WiWo | OpenFOAM | 0 | March 18, 2010 11:10 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
[blockMesh] Problem with blockMesh and cyclics | mattijs | OpenFOAM Meshing & Mesh Conversion | 1 | May 26, 2006 06:41 |
