OpenFoam vs Fluent
Old   January 27, 2011, 08:07
Default OpenFoam vs Fluent
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
I try to calculate a flow around building. So, I did a mesh in gambit and calculate in Fluent. After this, I load mesh in OpenFoam and try to calculate in it. I use the same boundary condition, but every time i have very big value of time step continuity error, epsilon and k.
I use a k-epsilon model in SimpleFoam.
Why Fluent calculate my problem, and OpenFoam can't?
Akuji is offline   Reply With Quote
Old   January 27, 2011, 09:58
Smile
Charlie
cheng1988sjtu is on a distinguished road
Is it a 2D model?
Can you use checkMesh in OpenFoam to see the detail of the mesh?
Maybe you've got some undefined faces...
cheng1988sjtu is offline   Reply With Quote
Old   January 27, 2011, 10:01
Arina
Originally Posted by cheng1988sjtu View Post
Is it a 2D model?
My Mesh is 3D. I always use checkMesh after import it from another application. Mesh is OK
Old   January 28, 2011, 03:47
Matthias Voß
mvoss is on a distinguished road
please check for the internal fields in ~/0/epsilon,k,u and of cource for the bc.values (garbage in , garbage out... )
i think you just started with unphysical internal values. no offense, but as often is i blew up a solver run as often it was my fault because of bad initialization and fancy bc.
try to do a potentialFoam on beforehand to get an initial guess.
neewbie
mvoss is offline   Reply With Quote
Old   January 28, 2011, 03:51
amgode's Avatar
Amol
amgode is on a distinguished road
Could you please elaborate a little more on your problem.....with regards to the schemes you used in OpenFoam and also the solvers used...
Regards,
Amol
Amol Gode
amgode is offline   Reply With Quote
Old   January 31, 2011, 08:15
Arina
today I try to use a Spalar-Allmaras model, because k-eps was converged only with vary small relaxation factors.
When I look velocity, I see, that in magnitude I have only positive values, in axes y and z-positive and negative. But in X-only positive, so as I understand I haven't a vortex.
But fluent shows a lot of vortexes.
Where mistake?
Old   February 1, 2011, 01:30
Alberto Passalacqua
before we can try to answer you should give us a bit more information :-)
- What solver are you using?
- Post your fvSchemes and your fvSolution dictionaries
- Post the output of checkMesh
- Describe the setup of your boundary conditions
Typically if you are forced to use very small relaxation factors, it means there is something wrong in the case setup (I would say most probably BC's).
Best,
Alberto Passalacqua
Old   February 2, 2011, 07:39
Arina
I use case simpleFoam
My fvSchemes and fvSolution
Also, output of checkMesh-in log file
And boundary Conditions are in 0.zip
[Other] OpenFoam Mesh to Fluent Mesh, 2D lordvon ANSYS Meshing & Geometry 1 January 14, 2022 12:20
[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam matteo_gautero OpenFOAM Meshing & Mesh Conversion 11 July 14, 2020 12:09
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Fluent OpenFoam comparison kepsilon model alimansouri OpenFOAM Running, Solving & CFD 5 January 19, 2009 09:35
Matching Velocity and Pressure fields Fluent OpenFoam alimansouri OpenFOAM Running, Solving & CFD 0 January 13, 2009 17:51
