[snappyHexMesh] snappyhexmesh problem
Old   February 1, 2011, 08:14
Default snappyhexmesh problem
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi all,
I am a realtively new user of snappyhexmesh. I was trying to adapt the motorbike tutorial for my own problem, to use snappyhexmesh. But it seems to give an error which i cannot understand.
----------------------------------------------from terminal---------------------------------------
Create time
Create mesh for time = 0
Read mesh in = 0.26 s
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/users/ali/crucible/crucible01/system/decomposeParDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
-----------------------------------------end-------------------------------------------------------
any help idea or source would be of great value to me.
owayz is offline   Reply With Quote
Old   February 1, 2011, 09:23
DanielPT is on a distinguished road
did you edited something in your decomposeParDict? I never had a problem like this.
Regards
DanielPT is offline   Reply With Quote
Old   February 1, 2011, 10:03
Awais Ali
I am a new user, so I have no idea what dict is it. I havent modified anything. I just tried to do the simple thing. By running blockMesh first and then to refine and snap, I tried to use the snappy hex mesh.
I have also attached my snappyHexMesh dict.
Old   February 1, 2011, 10:20
Hello again,
ok please look in your systems folder. Is there a decomposeParDict inside? When not, copy it from a tutorial.
I attached two useful tutorials for snappyHexMesh.
http://www.hydroniumion.de/allgemein...mesh-tutorial/
http://www.hydroniumion.de/studium/s...torial-part-2/
http://cfdcomputing.com/documents/foam_meshing.htm
Old   February 2, 2011, 07:29
Default hi and thanks
Awais Ali
Hi Daniel Thanks for zour help, yes I coped that file from the tutorial and now atleat its trying to do something. But I have an error.
First I will explain my problem:
My problem is not very difficult. I have a half sphere for which I have to creat an internal mesh. My surface is in stl format. I create a rectangular box completely enclosing the sphere. I specify the locationinmesh to be a point inside the half sphere. And I was expecting to to get refinement and snapping at surfaces. Thanks for the tutorials, I have seen them already before, but don't know whz i didn't find them very helpful.
I have attached a file that contains the log from terminal, please have a look at it and tell me the possible reasons of the behavior.
Old   February 2, 2011, 07:33
Awais Ali
Sorry there was some problem the file was not attached.
Here is the file again.
Old   February 2, 2011, 12:16
your log file tells me, that expansionRatio isn't definded in snappyHexMeshDict .
Look in the addLayer part. Maybe you have forgotten a semicolon or the whole entry.
Daniel
open foam, snappyhexmesh
[snappyHexMesh] Problem with decomposePar, snappyHexMesh luca1992 OpenFOAM Meshing & Mesh Conversion 12 August 23, 2017 19:06
[snappyHexMesh] snappyHexMesh problem cfdsolver1 OpenFOAM Meshing & Mesh Conversion 0 June 23, 2016 10:09
[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 0 November 21, 2015 13:57
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 14:46
[snappyHexMesh] Problem with snappyHexMesh giack OpenFOAM Meshing & Mesh Conversion 2 September 18, 2014 10:03
