February 1, 2011, 13:12 |
Simple pressure difference question
Ammar Tareen
Hello everybody,
Kindly help me with a simple question: I have a rectangular tube, with one inlet and one outlet. I want to flow air through that tube. For my BC, I want higher pressure on the inlet and lower pressure on the outlet so that air will flow. My question is, will I need to specify the value of pressure at the internal field? or is specifying the boundary conditions at the inlet and outlet sufficient? please let me know! THAAANKS! :-) |
February 1, 2011, 16:16 |
Ammar Tareen
Please any help would appreciated!
Thank you. |
February 2, 2011, 04:39 |
For flows in a channel with inlet and outlet, the following BCs (0 folder) are often used: - inlet: U fixedValue U_0, p zero gradient - outlet: U zero gradient, p fixed value p_0 - internal field: U uniform U_0, p uniform p_0 |
air, flow, pressure bc, tube |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
Question on Pressure and Velocity Fields with SIMPLE algorithm | Phiper | Main CFD Forum | 0 | November 18, 2010 18:29 |
Collocated SIMPLE and outlet pressure | yhoarau | Main CFD Forum | 1 | April 16, 2009 09:16 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Pressure correction question - Please help! | Barry | Main CFD Forum | 1 | February 5, 2003 00:27 |
