blockMesh - parallel mesh generation
Like Tree11Likes
  • 1 Post By WolfgangS.
  • 2 Post By gschaider
  • 7 Post By Hisham
Old   February 2, 2011, 04:52
Default blockMesh - parallel mesh generation
Wolfgang Strauss
WolfgangS. is on a distinguished road
Hi Foamers!
I have just a short question.
Is a parallel mesh generation with blockMesh possible?
Thanks and best regards!
Wolfgang
chitransh_atre likes this.
WolfgangS. is offline   Reply With Quote
Old   February 3, 2011, 04:21
Felix W.
Rusty Velo is on a distinguished road
Hi Wolfgang,
I'm not sure, what you're meaning with a parallel mesh generation.. But if you want to define a rectangular area with a mesh (existing of rectangular cells, which can have regular or irregular dimensions): This is possible.
I normally define my (3d) domains with BlockMesh and insert other geometries with snappyHexMesh.. But I'm still a Beginner in OF, so that this is maybe not the best way for a geometry preparation..
best regards,
felix
Rusty Velo is offline   Reply With Quote
Old   February 3, 2011, 04:59
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
I think he meant if he can run blockMesh in parallel, and I think the answer is no.
akidess is offline   Reply With Quote
Old   February 3, 2011, 08:00
Wolfgang Strauss
hi felix and akidess
akidess is right.
By now i used...
blockMesh
decomposePar
mpiexec -n 12 snappyHexMesh -parallel
... and it worked fine.
Thanks akidess for your quick answer.
Best regards
Wolfgang
lav likes this.
Old   January 15, 2013, 09:19
mo houssami
mo.houssami is on a distinguished road
Hi Foamers,
Now that we're in 2013 , do you know if there's a way to run blockMesh in parallel?
I am trying to run a 3D case on a cluster, with 28 blocks and a total of 67x10^6 cells... Hence, blockMesh it taking forever.
Do you have any suggestions?
Thanks
mo.houssami is offline   Reply With Quote
Old   January 15, 2013, 10:42
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by mo.houssami View Post
Hi Foamers,
Yeah. Use a more sensible mesh.
No seriously: blockMesh doesn't work in parallel and would be hard to write such a thing in parallel (think about it: you're asking the decomposition algorithm to know how to decompose before the actual cells are known).
Anyway: one way would be the following (I'm only sketching this. You have a cluster for a 67m cell mesh so I assume you either have the time to set this up yourself or the money to buy support to do this for you):
- set up blockMeshes for single blocks (or small managable groups). Set up patches for the processor patches (but give them the type patch)
- run blockMesh on each of these blocks
- copy the constant/polyMesh into the appropriate processorX/constant/polyMesh directory
- either edit by hand or have a script to edit the polyMesh/boundary-files to change the type of the patches from patch to processor
Now you have a mesh that is decomposed for 28 processors (assuming each block gets his own processor). If that is not the number of processors you want to do the calculation with or if the mesh is unbalanced because the blocks are not of the same cell number then you can use the redistributeParMesh utility to get an evenly distributed mesh on any number of processors you like.
All these steps can be scripted (even decomposing the big blockMeshDict into 28 dicts ... but it won't be pretty)
Hisham and Dave ZL like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   January 3, 2014, 18:56
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Although this seems to be a year later. I think a nice solution would also be to:
1. make a coarse mesh
2. decomposePar it
3. Edit: run topoSet in parallel to add sets to constant/polyMesh
in system/topoSetDict create a cellSet via a large box to include
all cells for refinement
3. run refineHexMesh as many times as you desire in parallel
Best regards,
Hisham
Hisham is offline   Reply With Quote
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
[snappyHexMesh] Parallel mesh generation using snappyHexMesh aki_yafuji OpenFOAM Meshing & Mesh Conversion 0 December 25, 2010 03:49
[blockMesh] Mesh generation without using blockMesh mamaly60 OpenFOAM Meshing & Mesh Conversion 1 November 1, 2007 02:45
