please help me with this gsl_integration error in hannes code
Old   January 31, 2011, 12:03
Default please help me with this gsl_integration error in hannes code
Farshad
Farshad_Noravesh is on a distinguished road
I would be very glad if someone could help me to solve the gsl_integration error that it occures during compiling Hannes repository.
I just copied gsl header files to a folder inside integrator folder which is inside compositionpdf folder.
The error is attached.
Kind Regards,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   January 31, 2011, 15:53
Hannes Kröger
hannes is on a distinguished road
Hello Farshad,
please note that I used this code together with OF-1.5. I guess some things have changed in OF-1.7.1 and some modifications need to be done.
I will try to port the code to OF-1.6-ext. I will let you know, if I made some progress.
Regards, Hannes
hannes is offline   Reply With Quote
Old   February 2, 2011, 05:43
Default last modifications
Farshad
Dear Hannes,
Thanks for sharing your useful code.I learned many things from that.I have modified make file for your library and only three small errors are left.
I think the problem is with the order of puting arguments in Cuhre function. I have attached my last log after i deleted GSL cause i didnt need one dimension as you mentioned.
Kind Regards,
Farshad
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 04:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Error in CFX Solver Leuchte CFX 5 November 6, 2010 06:12
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
