[swak4Foam] GroovyBC again
Old   February 16, 2011, 11:57
Default GroovyBC again
Rickard
Rickard.Solsjo is on a distinguished road
Hi again. Still some groovy problems.
Does anyone know what this problem may be due to?
[15] Parser Error at "1.0-5" :"field Uinlet not existing or of wrong type"
"Uinlet=Uz*cos(theta)*vector(0,0,1)+Uz*sin(theta)* vector(0,1,0)+Uz*sin(theta)*vector(1,0,0)"
[15]
[15] From function parsingValue
[15] in file PatchValueExpressionDriver.C at line 192.
[15]
FOAM parallel run exiting
jet
type groovyBC;
variables "Uz=150;rmax=0.0005;r=sqrt(pow(pos().x,2)+pow(pos( ).y,2));thetaMax=10.75*pi/180;theta=(thetaMax*r)/rmax;";
valueExpression "Uinlet=Uz*cos(theta)*vector(0,0,1)+Uz*sin(theta)* vector(0,1,0)+Uz*sin(theta)*vector(1,0,0)";
fractionExpression "(r<=0.5) ? U=Uinlet : U=vector(0,0,0)";
Rickard.Solsjo is offline   Reply With Quote
Old   February 16, 2011, 18:04
Assistant Moderator
Bernhard Gschaider
[15]
[15]
jet
type groovyBC;
You can't have an assignment inside of valueExpression (that is what variables is for). valueExpression IS an assignment
Old   June 16, 2011, 16:58
Default groovyBC error
Ulisses
ulisses is on a distinguished road
Hi guys,
I am trying to generate a parabolic profile using groovyBC:
inlet
type groovyBC;
variables "dirx=vector (1,0,0);dirz=vector (0,0,1);Umin=22;hx=mag(pos()*dirx);hz=mag(pos()*di rz);a=hx*hx+hz*hz;speed=Umin*a";
valueExpression "vector (0, speed, 0)";
But I've got the following error:
PHP Code:
    Cannot find 'value' entry on patch entrada of field Ub in file "/home/ulisses/OpenFOAM/ulisses-1.6/run/leitodejorroGroovy/0/Ub"
which is required to set the values of the generic patch field.
Actual type groovyBC)
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file
: /home/ulisses/OpenFOAM/ulisses-1.6/run/leitodejorroGroovy/0/Ub::entrada from line 36 to line 39.
    From
function genericFvPatchField<Type>::genericFvPatchField(const fvPatch&, const Field<Type>&, const dictionary&)
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72.
FOAM exiting
Do you have any suggestion?
Thanks
ulisses is offline   Reply With Quote
Old   June 16, 2011, 17:28
Ulisses
I already discovery my mistake.
I wrote in the wrong place in system/controlDict:
libs ("libgroovyBC.so")
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
