chtMultiRegionFoam + Sphere mesh + makeCellset.setSets
Old   March 21, 2011, 08:53
Default chtMultiRegionFoam + Sphere mesh + makeCellset.setSets
Alpesh
alvora is on a distinguished road
Hello friends,
I am using chtmultiregion foam to solve my problem. I changed the chtmultiregionFoam solve according to my requirement and I run on heater problem which gave perfect result.
But, I need sphere in my problem instead of heater. Two spheres are in one cube.
I also found the command "cylinderToCell" from utilities/mesh/manipulation/cellsets.
In heater problem, the geometry is simple, hence, it is easy to define by blockMesh and after that by makeCellSet.setSets. But, for sphere, how we can define in blockMeshDict and makecellSet.setSet file?
can we define cube in blockMeshDict and sphere from makecellset.setset file by using cylinderToCell command? if yes, how we can subtract a sphere from the cube?
Or should I have to use snappyHexMesh? then, can snappyHexMesh combine in shtmultiregionfom for two different region?
or should I have to make a geometry in gmsh or any other software and import in opefoam?
please, tell me which one is possible and easy..
Thanx in advance
kind regards
Alpesh
alvora is offline   Reply With Quote
Old   March 21, 2011, 09:49
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
Hello Alpesh,
It is even easier than that. You can use sphereToCell
cellSet c0 new sphereToCell (cx cy cz) R
Usage: sphereToCell (centreX centreY centreZ) radius
Select all cells with cellCentre within bounding sphere
Good luck,
Frederic
PS: Remember that the sphere won't have a spherical shape but will be approximate by the elements (probably hexahedrons) of the mesh. If you really need a good surface, you will have to move to dedicated mesh tools.
Frederic Collonval
Technische Universität München
Thermodynamics Dpt.
fcollonv is offline   Reply With Quote
Old   March 21, 2011, 10:08
Alpesh
Hi Frederic Collonval,
Thank you very much for your reply...
I tried with that and I got sphere shape but it is not really sphere.. I think I have to use very dense mesh..then surface will transform in spherical shape..
But, I am getting problem in surrounding air region.. should I have to define surrounding region in makecellsets.setset or in blockmeshDict?
regards
alpesh
Old   March 21, 2011, 11:47
Default Generate geometry for multi-domain simulation
Frederic Collonval
It is what I meant with the PS before...
Okay let describe the Allrun script of the tutorial chtMultiRegionSimpleFoam
rm -rf constant/polyMesh/sets //remove the previous sub-parts of the mesh
runApplication blockMesh // create the mesh for all parts (don't care about the properties of the cells)
runApplication setSet -batch makeCellSets.setSet // split the mesh in sub region - the best is selected obvious part (like the sphere) in separate cellSet and select the other cells by selecting all the previously created parts and finally inverting the selection
rm -f constant/polyMesh/sets/*_old // Remove not needed part
runApplication setsToZones -noFlipMap // Transform the sets in Zones
runApplication splitMeshRegions -cellZones -overwrite // create the regions from the zones
So a solution is to create the mesh with blockMesh having the size of the cube. Then you select the two spheres in dedicated cellSet and create a last set containing every cells except those of the spheres.
Good luck,
Frederic
Frederic Collonval
Thermodynamics Dpt.
Old   March 22, 2011, 02:44
Alpesh
Thank you very much for your help..
I tried and it's working perfectly..
but, when I tried to make dense mesh, some pointer error came. so, I think I have to make mesh in other opensource pre-processing software to get perfect sphere shape. can I do that way?
again thanx alt..
regards
Alpesh
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
potentialFoam around a sphere ; mesh by Gmsh eliam OpenFOAM Running, Solving & CFD 12 January 26, 2011 03:02
dynamic mesh - sphere falling through fluid volume accelerated by gravity onely. alexmeier FLUENT 1 June 26, 2010 08:33
hexa mesh around a sphere within a cylinder:fluent HK Main CFD Forum 1 March 20, 2008 10:54
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
